Preface : I had "No wifi adapter found" issue on my pc. I asked No wifi adapter found on Ubuntu 20.04.3 LTS, & the answer chili555 given was working fine.
Today after a restart, I am encountering a new issue. Now, wifi is enabled but it can't find any wifi networks. (though USB-Tethering works). The kernel version is 5.13.0-27-generic
- Output of
iwconfig:
lo no wireless extensions.
usb0 no wireless extensions.
wlp1s0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=3 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
docker0 no wireless extensions.
sudo lshw -C network:
*-network
description: Wireless interface
product: MEDIATEK Corp.
vendor: MEDIATEK Corp.
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlp1s0
version: 00
serial: c8:94:02:c1:7a:7b
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=mt7921e driverversion=5.13.0-27-generic firmware=____010000-20211014150922 latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:88 memory:e0300000-e03fffff memory:e0400000-e0403fff memory:e0404000-e0404fff
*-network
description: Ethernet interface
physical id: 1
bus info: usb@1:2
logical name: usb0
serial: 82:75:76:11:9e:70
capabilities: ethernet physical
configuration: autonegotiation=off broadcast=yes driver=rndis_host driverversion=5.13.0-27-generic duplex=half firmware=RNDIS device ip=192.168.42.130 link=yes multicast=yes port=twisted pair
rfkill list all:
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
sudo iwlist scan:
lo Interface doesn't support scanning.
usb0 Interface doesn't support scanning.
wlp1s0 No scan results
docker0 Interface doesn't support scanning.
lspci -nnk | grep 0280 -A3:
01:00.0 Network controller [0280]: MEDIATEK Corp. Device [14c3:0608]
Subsystem: MEDIATEK Corp. Device [14c3:0608]
Kernel driver in use: mt7921e
Kernel modules: mt7921e
sudo dmesg | grep mt7:
[ 3.629484] mt7921e 0000:01:00.0: enabling device (0000 -> 0002)
[ 3.629700] mt7921e 0000:01:00.0: disabling ASPM L1
[ 3.629746] mt7921e 0000:01:00.0: ASIC revision: 79610010
[ 3.712374] mt7921e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20211014150838a
[ 3.724385] mt7921e 0000:01:00.0: WM Firmware Version: ____010000, Build Time: 20211014150922
[ 3.754924] mt7921e 0000:01:00.0: Firmware init done
[ 5.326846] mt7921e 0000:01:00.0 wlp1s0: renamed from wlan0
I have also tried sudo apt-get install --reinstall network-manager, sudo systemctl restart network-manager.service, sudo /etc/init.d/network-manager force-reload, Reboot mutiple times. But No luck !!
