Ubuntu startup and works correctly but after a while it suddenly stop responding any more
Only the mouse is responding for movement but not clicks
No keyboard or menus, I only end with just a moving mouse cursor and nothing else
Letting the device for a while don't solve anything
I'm forced to unplug power cable and restart device every time
More occasionally when browsing internet or using VSCode, but not limited to that
Windows on the same machine never did that, and using windows is not an option
I need to know the problem and stop it
some helping info
----- >>> lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 20.04.3 LTS
Release:    20.04
Codename:   focal
----- >>> inxi -Fx System: Host: xxxxx Kernel: 5.4.0-96-lowlatency x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Xfce 4.14.2 Distro: Ubuntu 20.04.3 LTS (Focal Fossa) Machine: Type: Desktop System: Hewlett-Packard product: HP Compaq Elite 8300 MT v: N/A serial: <superuser/root required> Mobo: Hewlett-Packard model: 3397 serial: <superuser/root required> BIOS: Hewlett-Packard v: K01 v02.90 date: 07/16/2013 CPU: Topology: Quad Core model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge rev: 9 L2 cache: 6144 KiB flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25541 Speed: 3008 MHz min/max: 1600/3600 MHz Core speeds (MHz): 1: 3008 2: 2461 3: 2233 4: 2705 Graphics: Device-1: NVIDIA GT218 [GeForce 210] driver: nvidia v: 340.108 bus ID: 01:00.0 Display: x11 server: X.Org 1.20.13 driver: nvidia unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1200~60Hz OpenGL: renderer: GeForce 210/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108 direct render: Yes Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0 Device-2: NVIDIA High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1 Sound Server: ALSA v: k5.4.0-96-lowlatency Network: Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard driver: e1000e v: 3.2.6-k port: f040 bus ID: 00:19.0 IF: eno1 state: up speed: 100 Mbps duplex: full mac: xx:xx:xx:xx:xx:xx IF-ID-1: dbr_static state: up speed: N/A duplex: N/A mac: xx:xx:xx:xx:xx:xx IF-ID-2: docker0 state: down mac: xx:xx:xx:xx:xx:xx IF-ID-3: vetha603db9 state: up speed: 10000 Mbps duplex: full mac: xx:xx:xx:xx:xx:xx IF-ID-4: vetheee87ca state: up speed: 10000 Mbps duplex: full mac: xx:xx:xx:xx:xx:xx Drives: Local Storage: total: 530.92 GiB used: 50.64 GiB (9.5%) ID-1: /dev/sda vendor: Western Digital model: WD3200AAJS-00L7A0 size: 298.09 GiB temp: 27 C ID-2: /dev/sdb vendor: Seagate model: ST3250318AS size: 232.83 GiB temp: 23 C RAID: Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 bus ID: 00:1f.2 Partition: ID-1: / size: 54.75 GiB used: 30.41 GiB (55.5%) fs: ext4 dev: /dev/sda1 Sensors: System Temperatures: cpu: 20.0 C mobo: N/A gpu: nvidia temp: 26 C Fan Speeds (RPM): N/A Info: Processes: 267 Uptime: 56m Memory: 7.72 GiB used: 2.05 GiB (26.6%) Init: systemd runlevel: 5 Compilers: gcc: 9.3.0 Shell: zsh v: 5.8 inxi: 3.0.38
You have more then enough system resources to run Ubuntu. This issue is most likely due to a faulty driver of the graphics card.
Open software sources and go to the additional drivers tab.
Several drivers for the graphics card should be available. Choose one of them and restart the computer. Use it for some time and check it performance. Repeat, until you find the best driver.
