i'm currently using ubuntu 21.10 and i'm relatively new to linux so i'm not exactly sure how to change stuff but here's what i did seeking answers on diffrent forums
cpupower frequency-info
analyzing CPU 0:
  driver: acpi-cpufreq
  CPUs which run at the same hardware frequency: 0
  CPUs which need to have their frequency coordinated by software: 0
  maximum transition latency: 4.0 us
  hardware limits: 800 MHz - 3.20 GHz
  available frequency steps:  3.20 GHz, 2.50 GHz, 1.90 GHz, 800 MHz
  available cpufreq governors: conservative ondemand userspace powersave performance schedutil
  current policy: frequency should be within 800 MHz and 3.20 GHz.
                  The governor "schedutil" may decide which speed to use
                  within this range.
  current CPU frequency: Unable to call hardware
  current CPU frequency: 1.90 GHz (asserted by call to kernel)
  boost state support:
    Supported: no
    Active: no
i want to change it to performance since the OS is jittering while using it since it is not utilizing 100% of CPU power i tired doing this but got an error
sudo systemctl disable schedutil
Failed to disable unit: Unit file schedutil.service does not exist.
I'm not sure how to set performance governer permanently.
