I have new ubuntu server setup in Linode. I am trying to disable password logins and was successfull doing so for root users but unable to do so for a new user(lrehan) created by me.
root cannot login via password/ssh key lrehan can login without password or by not providing the ssh key (as there is no password prompt)
root login
  1. ssh root@ip - FAILED - EXPECTED RESULTS
  2. ssh -i ~./ssh/linode root@ip - FAILED - EXPECTED RESULTS
lrehan login
  1. ssh lrehan@ip - LOGS IN (NO PASSWORD PROMT) - NOT EXPECTED
  2. ssh -i ~./ssh/linode lrehan@ip - LOGS IN - EXPECTED RESULTS
Here is my sshd_config file
#       $OpenBSD: sshd_config,v 1.103 2018/04/09 20:41:22 tj Exp $
This is the sshd server system-wide configuration file. See
sshd_config(5) for more information.
This sshd was compiled with PATH=/usr/bin:/bin:/usr/sbin:/sbin
The strategy used for options in the default sshd_config shipped with
OpenSSH is to specify options with their default value where
possible, but leave them commented. Uncommented options override the
default value.
Include /etc/ssh/sshd_config.d/*.conf
#Port 22 #AddressFamily any #ListenAddress 0.0.0.0 #ListenAddress ::
#HostKey /etc/ssh/ssh_host_rsa_key #HostKey /etc/ssh/ssh_host_ecdsa_key #HostKey /etc/ssh/ssh_host_ed25519_key
Ciphers and keying
#RekeyLimit default none
Logging
#SyslogFacility AUTH #LogLevel INFO
Authentication:
#LoginGraceTime 2m PermitRootLogin no StrictModes yes #MaxAuthTries 6 #MaxSessions 10
PubkeyAuthentication yes
Expect .ssh/authorized_keys2 to be disregarded by default in future.
#AuthorizedKeysFile .ssh/authorized_keys .ssh/authorized_keys2
#AuthorizedPrincipalsFile none
#AuthorizedKeysCommand none #AuthorizedKeysCommandUser nobody
For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
HostbasedAuthentication no
Change to yes if you don't trust ~/.ssh/known_hosts for
#HostbasedAuthentication #IgnoreUserKnownHosts no
Don't read the user's ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
To disable tunneled clear text passwords, change to no here!
PasswordAuthentication no PermitEmptyPasswords no
Change to yes to enable challenge-response passwords (beware issues with
some PAM modules and threads)
ChallengeResponseAuthentication no
Kerberos options
#KerberosAuthentication no #KerberosOrLocalPasswd yes #KerberosTicketCleanup yes #KerberosGetAFSToken no
GSSAPI options
#GSSAPIAuthentication no #GSSAPICleanupCredentials yes #GSSAPIStrictAcceptorCheck yes #GSSAPIKeyExchange no
Set this to 'yes' to enable PAM authentication, account processing,
and session processing. If this is enabled, PAM authentication will
be allowed through the ChallengeResponseAuthentication and
PasswordAuthentication. Depending on your PAM configuration,
PAM authentication via ChallengeResponseAuthentication may bypass
the setting of "PermitRootLogin without-password".
If you just want the PAM account and session checks to run without
PAM authentication, then enable this but set PasswordAuthentication
and ChallengeResponseAuthentication to 'no'.
UsePAM no
#AllowAgentForwarding yes #AllowTcpForwarding yes #GatewayPorts no X11Forwarding yes #X11DisplayOffset 10 #X11UseLocalhost yes #PermitTTY yes PrintMotd no #PrintLastLog yes #TCPKeepAlive yes #PermitUserEnvironment no #Compression delayed #ClientAliveInterval 0 #ClientAliveCountMax 3 #UseDNS no #PidFile /var/run/sshd.pid #MaxStartups 10:30:100 #PermitTunnel no #ChrootDirectory none #VersionAddendum none
no default banner path
#Banner none
Allow client to pass locale environment variables
AcceptEnv LANG LC_*
override default of no subsystems
Subsystem sftp /usr/lib/openssh/sftp-server
Example of overriding settings on a per-user basis
#Match User anoncvs
X11Forwarding no
AllowTcpForwarding no
PermitTTY no
ForceCommand cvs server
Can someone direct me or help me on what is going wrong with this? Thanks!
Rehan
  • 101
I solved using this answer https://askubuntu.com/a/1440509/1713168
Inside the directory /etc/ssh/sshd_config.d/ there is only one .conf file (50-cloud-init.conf), but inside it contains the line: PasswordAuthentication yes
I changed the line to #PasswordAuthentication no
and i restarted the ssh. Now is working. I can only access with the ssh key.
