noob here!
Even by reading all that I could on stuff relating to my issue, I am still struggling to get my wifi working. Here are some details:
Hardware:
MSI Pro Z690-A Wifi motherboard (Intel Wifi 6E onboard module)
Software:
Freshly installed Ubuntu 20.04.3
Output from terminal:
uname -r
5.13.0-27-generic
lsmod | grep iwlwifi
iwlwifi               372736  0
cfg80211              888832  1 iwlwifi
sudo lshw -class network
-network UNCLAIMED
       description: Network controller
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 14.3
       bus info: pci@0000:00:14.3
       version: 11
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix cap_list
       configuration: latency=0
       resources: memory:6491c000-6491ffff
  -network
       description: Ethernet interface
       physical id: 0
       bus info: pci@0000:04:00.0
       logical name: enp4s0
       version: 03
       serial: d8:bb:c1:8f:39:7c
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi msix pciexpress bus_master cap_list ethernet physical 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=igc driverversion=5.13.0-27-generic duplex=full firmware=1079:8770 ip=192.168.50.13 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:18 memory:64600000-646fffff memory:64700000-64703fff
dmesg | grep iwl
[    2.005460] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    2.008773] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-63.ucode failed with error -2
[    2.008918] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-62.ucode failed with error -2
[    2.008928] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-61.ucode failed with error -2
[    2.009121] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-60.ucode failed with error -2
[    2.009132] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-59.ucode failed with error -2
[    2.009251] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-58.ucode failed with error -2
[    2.009339] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-57.ucode failed with error -2
[    2.009348] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-56.ucode failed with error -2
[    2.009356] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-55.ucode failed with error -2
[    2.009365] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-54.ucode failed with error -2
[    2.009372] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-53.ucode failed with error -2
[    2.009381] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-52.ucode failed with error -2
[    2.009390] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-51.ucode failed with error -2
[    2.009399] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-50.ucode failed with error -2
[    2.009408] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-49.ucode failed with error -2
[    2.009418] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-48.ucode failed with error -2
[    2.009427] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-47.ucode failed with error -2
[    2.009435] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-46.ucode failed with error -2
[    2.009445] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-45.ucode failed with error -2
[    2.009453] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-44.ucode failed with error -2
[    2.009462] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-43.ucode failed with error -2
[    2.009472] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-42.ucode failed with error -2
[    2.009480] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-41.ucode failed with error -2
[    2.009489] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-40.ucode failed with error -2
[    2.009499] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-39.ucode failed with error -2
[    2.009500] iwlwifi 0000:00:14.3: no suitable firmware found!
[    2.009502] iwlwifi 0000:00:14.3: minimum version required: iwlwifi-so-a0-gf-a0-39
[    2.009504] iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-so-a0-gf-a0-63
[    2.009505] iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
[12790.858270] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-63.ucode failed with error -2
[12790.858277] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-62.ucode failed with error -2
[12790.858282] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-61.ucode failed with error -2
[12790.858286] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-60.ucode failed with error -2
[12790.858290] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-59.ucode failed with error -2
[12790.858295] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-58.ucode failed with error -2
[12790.858299] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-57.ucode failed with error -2
[12790.858304] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-56.ucode failed with error -2
[12790.858309] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-55.ucode failed with error -2
[12790.858314] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-54.ucode failed with error -2
[12790.858318] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-53.ucode failed with error -2
[12790.858322] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-52.ucode failed with error -2
[12790.858327] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-51.ucode failed with error -2
[12790.858331] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-50.ucode failed with error -2
[12790.858335] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-49.ucode failed with error -2
[12790.858339] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-48.ucode failed with error -2
[12790.858344] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-47.ucode failed with error -2
[12790.858348] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-46.ucode failed with error -2
[12790.858353] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-45.ucode failed with error -2
[12790.858357] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-44.ucode failed with error -2
[12790.858362] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-43.ucode failed with error -2
[12790.858366] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-42.ucode failed with error -2
[12790.858370] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-41.ucode failed with error -2
[12790.858374] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-40.ucode failed with error -2
[12790.858378] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-39.ucode failed with error -2
[12790.858379] iwlwifi 0000:00:14.3: no suitable firmware found!
[12790.858381] iwlwifi 0000:00:14.3: minimum version required: iwlwifi-so-a0-gf-a0-39
[12790.858381] iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-so-a0-gf-a0-63
[12790.858382] iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
I can see that it complains about not finding suitable firmware, but I am at my wits end as to knowing what to do further... I've tried copying the latest firmware into the /lib/firmware dir and doing the modprobe cmd to no avail. I've also renamed the file iwlwifi-ty-a0-gf-a0.pnvm in /lib/firmware (not sure if I need to rename iwlwifi-so-a0-gf-a0.pnvm as well - tried it but it did not seem to make any difference) and rebooted with no luck.
Any help will be greatly appreciated as I am out of my depth here and really want to get this beast up and running.
Thanks in advance!
P.S. just as a by-note - the Bluetooth and Ethernet seems to work fine
