root@landicho:~# apt install --fix-broken
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following additional packages will be installed:
chromium-browser
The following NEW packages will be installed:
chromium-browser
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/48.3 kB of archives.
After this operation, 164 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Preconfiguring packages ...
(Reading database ... 295137 files and directories currently installed.)
Preparing to unpack .../chromium-browser_1%3a85.0.4183.83-0ubuntu0.20.04.2_amd64.deb ...
=> Installing the chromium snap
==> Checking connectivity with the snap store
==> Installing the chromium snap
error: snap "chromium" has "install-snap" change in progress
dpkg: error processing archive /var/cache/apt/archives/chromium-browser_1%3a85.0.4183.83-0ubuntu0.20.04.2_amd64.deb (--unpack):
new chromium-browser package pre-installation script subprocess returned error exit status 10
---snip--- I try all sorts of ways to clean this up, and they all fail. I have never been this stuck in some 15 years of using Ubuntu. I just want to eliminate the chromium and webdriver stuff to get my system normal again.
