My wifi card is not detected on Realtek Semiconductor Co., Ltd. Device a85a Ubuntu 20.04.3. I have tried all kinds of different threads that have a similar problem and nothing has worked. I get the following message:
0000:02:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device a85a
A teacher told me he thinks the "blob" is missing but I don't know what that means.
Here are some commands I have tried:
sudo modprobe rtw89pci
modprobe: FATAL: Module rtw89pci not found in directory /lib/modules/5.11.0-43-generic***
Is there something I can do to solve it? I've been trying to solve this problem for 2 months now and I'm a bit desperate.
THANK YOU FOR THE HELP
INFO
lspci -nnk | grep 0280 -A3
0000:02:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:a85a]
    DeviceName: WLAN
    Subsystem: Hewlett-Packard Company Device [103c:88e2]
10000:e0:1d.0 PCI bridge [0604]: Intel Corporation Device [8086:a0b0] (rev 20)
sudo lshw -class network *-network UNCLAIMED
description: Network controller product: Realtek Semiconductor Co., Ltd. vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:02:00.0 version: 00 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress cap_list configuration: latency=0 resources: ioport:3000(size=256) memory:52000000-520fff
I'm getting this by following the thread that @chili555 suggested:
changed everything to documents folder and I'm getting an error
Ama
  • 13
First of all, the correct driver for your device is indeed rtw89pci. Let's start from the beginning. With a working internet connection by ethernet, tethering or whatever means possible, open a terminal and do:
sudo apt update
sudo apt install git build-essential bc
Next, follow this process exactly: How to get Realtek RTL8852AE WiFi card to work on my new laptop
If applicable, you will have to disable Secure Boot.
Reboot and your wireless should now be working.
chili555
  • 61,330
