I am using Ubuntu 21.10 and have been having difficulties getting a Zoom session going. It was crashing each time I started a session, I found it necessary to restart Zoom usually 3, 4 or 5 times before it got going, once started it would stay working.
Ubuntu 21.10 uses a Snap install of the Zoom client
$ snap list zoom-client
Name         Version     Rev  Tracking       Publisher  Notes
zoom-client  5.9.1.1380  167  latest/stable  ogra       -
In the log file: ~/snap/zoom-client/current/.zoom/logs/zoom_stdout_stderr.log
I found entries that pointed to Zoom not being happy running with Wayland
qt.scenegraph.general: texture atlas dimensions: 512x1024
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
qt.scenegraph.general: Using sg animation driver
qt.scenegraph.general: Animation Driver: using vsync: 16.67 ms
qt.scenegraph.general: texture atlas dimensions: 512x512
file:///snap/zoom-client/167/zoom/QtQuick/Dialogs/DefaultFileDialog.qml:102:33: QML Settings: Failed to initialize QSettings instance. Status code is: 1
file:///snap/zoom-client/167/zoom/QtQuick/Dialogs/DefaultFileDialog.qml:102:33: QML Settings: The following application identifiers have not been set: QVector("organizationName", "organizationDomain")
This plugin does not support setting window opacity
Prior to version 21.10 Ubuntu's login screen had a button bottom right that gave you the option to select XOrg or Wayland, that has gone now so I needed a different way to select XOrg in preference to Wayland. I followed the instruction at:
[https://askubuntu.com/questions/1380829/no-option-to-choose-x11-on-logging-into-ubuntu-21-10][1]
This worked and the Zoom client now starts OK
Does anybody know how where to put this information and thus prompt a fix to make the zoom-client work with Wayland ?
