Problem
After some issues with the system state I reverted to a previous state snapshot.
Since then I systemctl is-system-running is in degraded state (I have it in my prompt).
The only failed service is zsys-commit.service and the status is:
● zsys-commit.service - Mark current ZSYS boot as successful
    Loaded: loaded (/lib/systemd/system/zsys-commit.service; enabled; vendor preset: enabled)
    Active: failed (Result: exit-code) since Sun 2022-01-23 23:21:41 EST; 10h ago
  Main PID: 12287 (code=exited, status=1/FAILURE)
Jan 23 23:21:40 hostname systemd[1]: Starting Mark current ZSYS boot as successful... Jan 23 23:21:41 hostname zsysctl[12287]: level=error msg="couldn't commit: couldn't promote dataset "rpool/ROOT/ubuntu_ssfirw": couldn't promote "rpool/ROOT/ubuntu_ssfirw": not a cloned filesystem" Jan 23 23:21:41 hostname systemd[1]: zsys-commit.service: Main process exited, code=exited, status=1/FAILURE Jan 23 23:21:41 hostname systemd[1]: zsys-commit.service: Failed with result 'exit-code'. Jan 23 23:21:41 hostname systemd[1]: Failed to start Mark current ZSYS boot as successful.
Questions
  1. How does zsys determines a dataset is cloned ?
    • following with: Can I modify that?
  2. What would be the best approach to cleanup all zsys states and remain with only the current state (with everything aligned, including the boot menu) ? See update #1 at the bottom
More details:
Some digging revealed that the command the service is running is:
/sbin/zsysctl boot commit
This is the output for sudo /sbin/zsysctl boot commit -vvv:
DEBUG /zsys.Zsys/CommitBoot() call logged as [79ef457a:5d32ce55]
DEBUG Check if grpc request peer is authorized
DEBUG Authorized as being administrator
INFO Commit current boot state
INFO Committing boot for "rpool/ROOT/ubuntu_ssfirw"
INFO Tag current user dataset: "rpool/USERDATA/szkolnik_vvk5gq"
DEBUG ZFS: trying to set "com.ubuntu.zsys:bootfs-datasets"="rpool/ROOT/ubuntu_1s4qqj,rpool/ROOT/ubuntu_ssfirw" on "rpool/USERDATA/szkolnik_vvk5gq"
INFO Tag current user dataset: "rpool/USERDATA/root_vvk5gq"
DEBUG ZFS: trying to set "com.ubuntu.zsys:bootfs-datasets"="rpool/ROOT/ubuntu_1s4qqj,rpool/ROOT/ubuntu_ssfirw" on "rpool/USERDATA/root_vvk5gq"
INFO set current time to "1643036037"
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "bpool/BOOT/ubuntu_ssfirw"
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw"
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/srv"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/srv" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/usr"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/usr" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/usr/local"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/usr/local" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var/games"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var/games" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var/lib"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var/lib" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var/log"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var/log" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var/mail"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var/mail" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var/snap"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var/snap" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var/spool"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var/spool" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var/www"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var/www" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var/lib/AccountsService"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var/lib/AccountsService" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var/lib/NetworkManager"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var/lib/NetworkManager" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var/lib/apt"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var/lib/apt" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/ROOT/ubuntu_ssfirw/var/lib/dpkg"
DEBUG ZFS: can't set property "com.ubuntu.zsys:last-used"="1643036037" for "rpool/ROOT/ubuntu_ssfirw/var/lib/dpkg" as not a local property ("inherited")
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/USERDATA/szkolnik_vvk5gq"
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-used"="1643036037" on "rpool/USERDATA/root_vvk5gq"
INFO Set latest booted kernel to "vmlinuz-5.13.0-27-generic"
DEBUG ZFS: trying to set "com.ubuntu.zsys:last-booted-kernel"="vmlinuz-5.13.0-27-generic" on "rpool/ROOT/ubuntu_ssfirw"
INFO Promoting user datasets
INFO Promoting system datasets
INFO Promoting dataset: "bpool/BOOT/ubuntu_ssfirw"
DEBUG ZFS: trying to promote "bpool/BOOT/ubuntu_ssfirw"
DEBUG Trying to promote "bpool/BOOT/ubuntu_ssfirw"
DEBUG ZFS: an error occurred: couldn't promote "bpool/BOOT/ubuntu_ssfirw": not a cloned filesystem
DEBUG ZFS: Cancelling nested transaction
DEBUG ZFS: ending transaction
DEBUG ZFS: reverting all in progress zfs transactions
DEBUG ZFS: transaction done
ERROR couldn't commit: couldn't promote dataset "bpool/BOOT/ubuntu_ssfirw": couldn't promote "bpool/BOOT/ubuntu_ssfirw": not a cloned filesystem
Update #1
I found this answer and based on that came up with the following code:
# List all bpool/BOOT states, from newest created to oldest
zfs list -r -t snapshot -S creation -o name,used,referenced,creation bpool/BOOT | sed '6 i --------------------------------------------------------------------------------'
I wanted to preserve the last 4 states, so I wrote the following code, removing all but 4 most recent states, from newest to oldest:
zfs list -r -t snapshot -S creation -Ho name bpool/BOOT | tail -n+5 | sed 's/.*@\(autozsys_\)\?//' | sudo xargs -i sh -c "echo removing {}...; zsysctl state remove {} --system --force || exit 255"
This however got stuck for me as a certain state is refusing to be removed:
ERROR couldn't remove system state kxxwbr: Couldn't remove state rpool/ROOT/ubuntu_ssfirw: Couldn't destroy rpool/ROOT/ubuntu_ssfirw: couldn't destroy "rpool/ROOT/ubuntu_ssfirw" and its children: stop destroying dataset on "rpool/ROOT/ubuntu_ssfirw", cannot destroy child: stop destroying dataset on "rpool/ROOT/ubuntu_ssfirw/usr", cannot destroy child: cannot destroy dataset "rpool/ROOT/ubuntu_ssfirw/usr/local": dataset is busy
For some reason, it is trying to destroy the active dataset.
Thinking I'm obviously not dealing with this correctly, I tried reversing the order, deleting from the oldest to newest (except the 4 most recent ones):
zfs list -r -t snapshot -s creation -Ho name bpool/BOOT | head -n-4 | sed 's/.*@\(autozsys_\)\?//' | sudo xargs -i sh -c "echo removing {}...; zsysctl state remove {} --force --system || exit 255"
This errored out at the same state, kxxwbr with the same error.
So I still need help with this.
Answering my own question, as it seems to be an issue with zfs maybe even specifically to zfs-on-linux and nothing to do with zsys.
Continuing my attempt to clean up snapshots manually, I eventually remained with a single state, currently named kxxwbr.
This kxxwbr state is associated with a dataset named 1s4qqj which was is the basis of a cloned dataset named ssfirw.
The following code will output the state clearly:
zfs list -o name,origin -S creation | grep -v '\W\-$'
outputs the following
NAME                                             ORIGIN
rpool/ROOT/ubuntu_ssfirw                         rpool/ROOT/ubuntu_1s4qqj@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/srv                     rpool/ROOT/ubuntu_1s4qqj/srv@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/usr                     rpool/ROOT/ubuntu_1s4qqj/usr@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/usr/local               rpool/ROOT/ubuntu_1s4qqj/usr/local@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var                     rpool/ROOT/ubuntu_1s4qqj/var@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var/games               rpool/ROOT/ubuntu_1s4qqj/var/games@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var/lib                 rpool/ROOT/ubuntu_1s4qqj/var/lib@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var/lib/AccountsService rpool/ROOT/ubuntu_1s4qqj/var/lib/AccountsService@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var/lib/NetworkManager  rpool/ROOT/ubuntu_1s4qqj/var/lib/NetworkManager@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var/lib/apt             rpool/ROOT/ubuntu_1s4qqj/var/lib/apt@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var/lib/dpkg            rpool/ROOT/ubuntu_1s4qqj/var/lib/dpkg@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var/log                 rpool/ROOT/ubuntu_1s4qqj/var/log@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var/mail                rpool/ROOT/ubuntu_1s4qqj/var/mail@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var/snap                rpool/ROOT/ubuntu_1s4qqj/var/snap@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var/spool               rpool/ROOT/ubuntu_1s4qqj/var/spool@autozsys_kxxwbr
rpool/ROOT/ubuntu_ssfirw/var/www                 rpool/ROOT/ubuntu_1s4qqj/var/www@autozsys_kxxwbr
When I try to promote any of the datasets, I get the following:
> sudo zfs promote rpool/ROOT/ubuntu_ssfirw
cannot promote 'rpool/ROOT/ubuntu_ssfirw': not a cloned filesystem
Searching Google for solutions gives a lot of issues, none of them (as of yet) provided any solutions.
Conclusion and a possible fix
It's BUG! (obviously, at this point)
This is my +1 in the bug thread:
https://bugs.launchpad.net/ubuntu/+source/zfs-linux/+bug/1947568/comments/5
I'm using the 3rd party PPA as described in the bug:
* THIS IS RISKY, so I take no responsibility for this, just reporting on what I've done.
# upgrade everything and cleanup before dealing with 3rd party content
sudo apt upgrade --yes
sudo apt autoremove --yes
add 3rd party PPA for zfstools
sudo add-apt-repository ppa:jonathonf/zfs &&
sudo apt update &&
you may get the following message in apt's output:
the following packages have been kept back:
zfs-initramfs zfs-zed zfsutils-linux
if that is the case explicitly update zfsutils-linux by running:
sudo apt install zfs-initramfs zfs-zed zfsutils-linux
At this point, promote should work properly.
And indeed, I used the following code to promote everything:
zfs list -Ho name,origin -S creation rpool/ROOT/ubuntu_ssfirw | grep -v '\W\-$' | sed 's/\t.*$//' | xargs -i sh -c "echo promoting {}; zfs promote {} || exit 255"
I went ahead and removed all snapshots (just because it was easier at this point), activated the garbage collector (sudo zsysctl service gc), then I was able to restart the zsys-commit.service.
Hopefully this will continue to work from this point forward, and someone might find this handy themselves.
Just wanted the supplement the great answer by @Lockszmith.
If after you promote, you run some commands to remove the apparently unused states as follows.
username@username-pc:~$ zsysctl state remove 4t8vy5
rpool/USERDATA/username_svq82i@autozsys_4t8vy5 has a dependency linked to some states:
  - rpool/USERDATA/username_ay5lx4 (2024-10-02 15:03:54) to remove. Currently linked to rpool/ROOT/ubuntu_zysz53
  - rpool/USERDATA/username_ay5lx4@autozsys_nxmr23 (2024-10-01 22:55:58)
  - rpool/USERDATA/username_ay5lx4@autozsys_duvtp2 (2024-10-01 18:55:32)
  - rpool/USERDATA/username_ay5lx4@autozsys_gco4g8 (2024-10-01 20:03:58)
  - rpool/USERDATA/username_ay5lx4@autozsys_i5iyec (2024-10-01 21:04:58)
  - rpool/USERDATA/username_ay5lx4@autozsys_ij9xjw (2024-10-01 22:45:38)
  - rpool/USERDATA/username_ay5lx4@autozsys_cho1od (2024-10-01 22:05:59)
  - rpool/USERDATA/username_ay5lx4@autozsys_9tvjo5 (2024-10-02 15:05:24)
  - rpool/USERDATA/username_ay5lx4@autozsys_o5ck50 (2024-10-01 19:03:41)
Would you like to proceed [y/N]? y
username@username-pc:~$ sudo zsysctl state remove 4t8vy5 rpool/USERDATA/root_svq82i@autozsys_4t8vy5 has a dependency linked to some states:
  • rpool/USERDATA/root_ay5lx4 (2024-10-02 15:03:54) to remove. Currently linked to rpool/ROOT/ubuntu_zysz53
  • rpool/USERDATA/root_ay5lx4@autozsys_duvtp2 (2024-10-01 18:55:32)
You may end up in a situation where "zsysctl show --full" reports there are no user datasets. I have no idea if rebooting would have forced it to detect them. But calling "zsysctl service refresh" didn't cause them to re-appear. So before rebooting and potentially ending up in an unbootable state I read the blog about how to link datasets to the root system dataset and set them. After doing this and calling "zsysctl service refresh" I could see the user datasets under "zsysctl show --full" again. Rebooting worked fine too and snapshots worked again.
sudo zfs set com.ubuntu.zsys:bootfs-datasets=rpool/ROOT/ubuntu_zysz53 rpool/USERDATA/root_svq82i
sudo zfs set com.ubuntu.zsys:last-used=1727849034 rpool/USERDATA/root_svq82i
sudo zfs set com.ubuntu.zsys:bootfs-datasets=rpool/ROOT/ubuntu_zysz53 rpool/USERDATA/username_svq82i sudo zfs set com.ubuntu.zsys:last-used=1727849034 rpool/USERDATA/username_svq82i
More details about what these parameters mean can be found on the following blog. https://didrocks.fr/2020/06/19/zfs-focus-on-ubuntu-20.04-lts-zsys-properties-on-zfs-datasets/
Hopefully this helps someone who is trying to get snapshotting working again after they did a rollback and ended up on a cloned userdata dataset based off a snapshot, that wasn't snap shotting properly.
Peter
  • 161
