Why do I continue to receive this error message:
The repository 'cdrom://Kubuntu 20.04.3 LTS _Focal Fossa_ - Release amd64 (20210819.1) focal Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
...and just exactly how does one go about correcting it?
Any information provided on the issue at hand is greatly appreciated.
Artur Meinild
  • 31,035
Cyborg
As mentioned by Archisman Panigrahi, You need to open the software and update app and disable the CDrom repository.
  1. Open the software sources file known as sources.list:
    sudo nano /etc/apt/sources.list
  2. Find the line which looks similar to:
    deb cdrom:[Ubuntu Desktop <version> <codename> - x86] <code name> <reponames>
    Most likely it will be the first line.
  3. Comment the line by putting a # after it.
    # deb [<foo> <foo> blah blah whatever] foobar whatever...
    You can also remove the line if you want.
  4. Run update:
    sudo apt update
Alternatively, you can change the /etc/apt/sources.list to:
deb http://archive.ubuntu.com/ubuntu/ focal main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ focal main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ focal-updates main restricted universe multiverse deb-src http://archive.ubuntu.com/ubuntu/ focal-updates main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse deb-src http://archive.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse deb-src http://archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
deb http://archive.canonical.com/ubuntu focal partner deb-src http://archive.canonical.com/ubuntu focal partner
And run apt update:
sudo apt update
An alternate GUI way to do the same:
  1. First, open Software & updates app.
    sudo apt install software-properties-gtk
    sudo software-properties-gtk
  2. Then navigate to other sourcesKubuntu CDrom. The name may not be the same, you just need to uncheck anything which says "CDrom" or similar to it.
  3. Uncheck it or remove it.
  4. Update:
    sudo apt update
That's it!
Good Luck!
Error404
  • 8,278
  • 35
  • 60
