I'm formatting a new 1TB HDD with a single dos partition; sdb1.
Typing sudo e2fsck -f /dev/sdb1:
$ sudo e2fsck -f /dev/sdb1
e2fsck 1.44.1 (24-Mar-2018)
ext2fs_open2: Bad magic number in super-block
e2fsck: Superblock invalid, trying backup blocks...
e2fsck: Bad magic number in super-block while trying to open /dev/sdb1
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
I have a single partition, no extended partitions. I'm not sure what this message refers to. I have tried a variety of suggestions without success.
Is there an error or does this refer only to (nonexistent) extended partitions? Should I ignore this and continue and expand the space using resize2fs?
