I have 2 disks in my PC, one for Linux and one for Windows. I select which one to boot from on my Asus X570-Pro which should be set to UEFI mode.
I was careless today and now only see the Ubuntu disk in the Asus boot menu. I don't know how this happened, but I spent the day installing Ubuntu 21.10 and Lubuntu 21.10 on the Linux disk.
The Windows disk uses BitLocker.
The data appears to be on the Windows disk, but there is no EFI partition. It's possible I had Windows Boot Manager on the Linux disk and overwrote it. I wonder if that means the Windows EFI partition was really on the Linux disk. Hard to say now.
The following output from parted, lsblk, and blkid show where things stand.
How can I rescue data on the Windows disk? I can either boot from it like I used to, or I can mount it and then copy off data. Remember it's BitLockered.
parted:
Disk /dev/nvme1n1: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: Seagate FireCuda 520 SSD ZP2000GM30002
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 07C2D22A-8354-42A6-9370-ADEA88468A3A
Device Start End Sectors Size Type
/dev/nvme1n1p1 2048 34815 32768 16M Microsoft reserved
/dev/nvme1n1p2 34816 3905807594 3905772779 1.8T Microsoft basic data
/dev/nvme1n1p3 3905808384 3907028991 1220608 596M Windows recovery environment
lsblk:
nvme1n1
├─nvme1n1p1
├─nvme1n1p2 BitLocker 2
└─nvme1n1p3 ntfs 0C80AE9780AE86B4
blkid:
/dev/nvme1n1p2: TYPE="BitLocker" PARTLABEL="Basic data partition" PARTUUID="9798e4e2-67e4-4e89-b989-fe6dd96d0c1c"
/dev/nvme1n1p3: BLOCK_SIZE="512" UUID="0C80AE9780AE86B4" TYPE="ntfs" PARTUUID="38ca4738-b773-40c3-a7fe-6d35c2d71d88"
/dev/nvme1n1p1: PARTLABEL="Microsoft reserved partition" PARTUUID="28b4f691-4f75-4737-9581-eb1f25aa187b"
Edit: It's now a few days later and here's more information. I gave up and reinstalled Windows. Curiously, it did not create an EFI System Partition but instead used the EFI partition created by Ubuntu on my first hard drive. That's what got me into this trouble in the first place. I had reinstalled Linux on the first drive and selected "use entire disk". This erased the ESP on the first disk which prevented me from booting Windows on the second disk. Ok, the mystery of how I got into trouble was solved. I researched how to put the Windows Boot Manager onto the ESP on the first (Linux) disk, but gave up and reinstalled Windows. I had no important data on the Windows disk. Mostly I wanted to fix this problem just out of principle. I couldn't understand what caused the problem, but now I do.
