I've had 21.10 installed for a while but have noticed that 'vim --version' brings up the info for 'nvim'. Is there any reason why this is happening?
Asked
Active
Viewed 2,266 times
Neither vim nor neovim are installed by default on an Ubuntu system. By default, Ubuntu comes with a minimal version of Vim through the package vim-tiny.
If on your system, 'vim --version' brings up information on neovim, which is a fork of vim, then it means you once installed neovim (package neovim). During installation, that package will have the commands vi and vim point to nvim (/usr/bin/nvim) using the "debian alternatives" system:
sudo apt install neovim
Setting up neovim (0.4.4-1) ...
update-alternatives: using /usr/libexec/neovim/ex to provide /usr/bin/ex (ex) in auto mode
update-alternatives: using /usr/libexec/neovim/rvim to provide /usr/bin/rvim (rvim) in aut
o mode
update-alternatives: using /usr/libexec/neovim/rview to provide /usr/bin/rview (rview) in
auto mode
update-alternatives: using /usr/bin/nvim to provide /usr/bin/vi (vi) in auto mode
update-alternatives: using /usr/bin/nvim to provide /usr/bin/vim (vim) in auto mode
update-alternatives: using /usr/libexec/neovim/view to provide /usr/bin/view (view) in aut
o mode
update-alternatives: using /usr/libexec/neovim/vimdiff to provide /usr/bin/vimdiff (vimdif
f) in auto mode
These links will be set up only if they are not already enabled. For example, if you previously installed vim, the commands vi and vim will continue to point to vim, /usr/bin/vim.basic. By default, the command vim is not available, and vi points to /usr/bin/vim.tiny.
vanadium
- 97,564
