I'm running ubuntu 18 cli server and I'm totally new The server provider gave me 50G more disk space but I need to add it myself. I know how to add with removing my data and configs but I want to keep all my current data and configs.
MY DF:
root@vps81785:~# df
Filesystem     1K-blocks     Used Available Use% Mounted on
udev              493172        0    493172   0% /dev
tmpfs             100848     7884     92964   8% /run
/dev/vda1       82534960 72218004   6106508  93% /
tmpfs             504236      124    504112   1% /dev/shm
tmpfs               5120        0      5120   0% /run/lock
tmpfs             504236        0    504236   0% /sys/fs/cgroup
tmpfs             100844        0    100844   0% /run/user/0
Levi
  • 13
Please make sure you have a backup before you the following.
You need to first increase the size of the partition, and then the size of the file system in it.
I find resizing partitions easiest with cfdisk. So it would probably be sudo cfdisk /dev/sda (but the /dev/sda could be different, look into /etc/fstab to find out your root partition device).
cfdisk should show you free space after the root partition (assuming it's /dev/sda1). Choose resize at the bottom. It will automatically propose the new maximum possible size. Write the changes and quit cfdisk.
Once that's done, best do a reboot, so that the partition table is re-read.
Then resize your filesystem. If it's the usual ext4, it's as simple as resize2fs /dev/sda1.
nagelp
  • 423
