My Intel Wifi 6 AX210 card is not detected on my fresh Ubuntu Mate installation.
Here is the dmesg output:
[    3.341328] iwlwifi 0000:92:00.0: enabling device (0000 -> 0002)
[    3.349932] iwlwifi 0000:92:00.0: api flags index 2 larger than supported by driver
[    3.349945] iwlwifi 0000:92:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 93.8.63.28
[    3.350218] iwlwifi 0000:92:00.0: loaded firmware version 59.601f3a66.0 ty-a0-gf-a0-59.ucode op_mode iwlmvm
[    3.369931] iwlwifi 0000:92:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[    3.538721] iwlwifi 0000:92:00.0: loaded PNVM version 0x324cd670
[    3.641027] iwlwifi 0000:92:00.0: Timeout waiting for PNVM load!
[    3.641033] iwlwifi 0000:92:00.0: Failed to start RT ucode: -110
[    3.641036] iwlwifi 0000:92:00.0: iwl_trans_send_cmd bad state = 1
[    3.845149] iwlwifi 0000:92:00.0: firmware didn't ACK the reset - continue anyway
[    3.857218] iwlwifi 0000:92:00.0: Failed to run INIT ucode: -110
My kernel version is:
Linux Precision-7560 5.11.0-27-generic #29~20.04.1-Ubuntu SMP Wed Aug 11 15:58:17 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Any idea to correct this? Linux Kernel from 5.10 may support this Wifi card : https://www.intel.com/content/www/us/en/support/articles/000005511/wireless.html
Thanks.
Hexa42
  • 33
For 20.04 (focal fossa)
This is a well-known bug #212371
Let's try the suggested fix:
  1. Open a terminal by pressing Ctrl + Alt + T .
  2. Run the following command:
    sudo mv /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm  /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.bak
  3. Reboot to reload the drivers.
EDIT: It appears that periodic updates to the package linux-firmware will install a new version of the offending file iwlwifi-ty-a0-gf-a0.pnvm and so this process will need to be repeated.
Good Luck!
Alternatively, installing a newer kernel will fix this issue. In the bug report, users have specifically mentioned kernel 5.16 (for 20.04 only). Here are step by step instructions to install it.
  1. Change the working directory to ~/Downloads :
    cd ~/Downloads
  2. Download the kernel's .deb files:
    wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.16/amd64/linux-headers-5.16.0-051600_5.16.0-051600.202201092355_all.deb
    wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.16/amd64/linux-headers-5.16.0-051600-generic_5.16.0-051600.202201092355_amd64.deb
    wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.16/amd64/linux-image-unsigned-5.16.0-051600-generic_5.16.0-051600.202201092355_amd64.deb
    wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.16/amd64/linux-modules-5.16.0-051600-generic_5.16.0-051600.202201092355_amd64.deb
  3. Install the .deb files:
    sudo dpkg -i *.deb
  4. Satisfy the dependencies.
    sudo apt -f install
That's it!
Good Luck!
Error404
  • 8,278
  • 35
  • 60
