So,
I noticed that on manjaro, if there is only one user, typing reboot without sudo, will just fail and ask for the sudo password, whereas on ubuntu server, typing this doesn't ask for the sudo password and successfully reboot the system. My question is how can I make it so that when I type reboot/shutdown/halt, ubuntu always asks for the sudo password even if there is only one user currently logged in ? May this have to do with polkit ? If so, how can I change this ?
The reason I'm asking this, is that I want to be sure that everyone that could have physical access to my server won't be able to reboot (unless of course by unplugging the power cable which is something different lol)
Thank you
Liwinux
  • 53
One of the ways that I've done this is by masking the systemd targets, which prevents certain actions from being performed, regardless of who enters the command. For example, to prevent the system from being shutdown, you can do this:
sudo systemctl mask poweroff.target
Now any attempt to shutdown the system via sudo shutdown or sudo systemctl shutdown will silently fail. The same can be done with halting and reboots:
sudo systemctl mask runlevel0.target
sudo systemctl mask halt.target
sudo systemctl mask runlevel6.target
sudo systemctl mask reboot.target
Note: runlevel6 is equivalent to reboot, and runlevel0 is equivalent to shutdown and halt.
To undo this, these commands can be run again, but with unmask:
sudo systemctl unmask runlevel0.target
sudo systemctl unmask shutdown.target
sudo systemctl unmask halt.target
sudo systemctl unmask runlevel6.target
sudo systemctl unmask reboot.target
With this in mind, now you can write a script that is executable only for people with sudo access:
#!/bin/bash
Determine the operation to run (mask | unmask)
op=mask
if [[ $1 = unmask ]] then op=unmask fi
Set the targets we want to mask
declare -a arr=("runlevel0" "runlevel6" "shutdown" "reboot" "halt")
Run the commands
for i in "${arr[@]}" do cmd=$( sudo systemctl $op $i.target ) echo "$i :: $op" done
WARNING: This code will work, but it's pretty rough. Be sure to sanity check it with a VM or somewhere "safe" before running it on a production box.
Now you can have this script run to mask the targets after booting up, and shutdown/reboot like this:
sudo ~./setTargetMask.sh unmask
sudo shutdown now
Note: Feel free to call the script whatever you'd like.
matigo
  • 24,752
  • 50
  • 79
