I've connected my hard drive by usb but the contents do not appear in /media.
When I mount it manually using mount /dev/sdb1 /media/user it succeeds.
When I list the contents of the fstab this is what I get:
#cat /etc/fstab
# /etc/fstab: static file system information.
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/sda2 during installation
UUID=number / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/sda1 during installation
UUID=number /boot/efi vfat umask=0077 0 1 /swapfile none swap sw 0 0
I am not sure if the device should appear there, also running lsblk, I see it (sdb1):
$ lsblk -f
sdc
└─sdc1 ntfs     username id
Why it is not mounting automatically?
EDIT: included a better description of the problem.
You have to create a new entry in the /etc/fstab file.
  1. with this command:
sudo  blkid
you get important information which UUID-number your /dev/sdb1 drive have. Save the number in a text-file.
  1. Create the directory for the target path, where you want to mount your new drive. As an example you can chose a folder with the name "mydata" in your home directory. Maybe: "/home/minsky/mydata "
There you can save all your personal data and they are separated from the operating system HDD and the OS-partition.
  1. Then you can create the new mountpoint in your fstab file.
Open the /etc/fstab file with:
sudo mousepad /etc/fstab
and create a new line where you can put in a line like this:
# My 1TByte SSD or HDD
UUID=50eebbff-8f43-4a11-8877-8abb2233246     /home/minsky/mydata    ext4    defaults,noatime,nodiratime,discard,nobh,data=ordered,commit=120          0       2
Replace the UUID number in this example with the number from your research.
Now your fstab would looks like this:
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda2 during installation
# /boot/efi was on /dev/sda1 during installation
Note:
You can see the type of the filesystem with:
df -T
If your drive is an SSD (or M.2 - SSD) and formated with f2fs (the flash friendly filesystem), then your mount entry in fstab should looks like this:
# My 1TByte SSD
UUID=50eebbff-8f43-4a11-8877-8abb2233246     /home/minsky/mydata    f2fs      rw,noatime,nodiratime,nosuid,nodev,discard,background_gc=off,inline_xattr,active_logs=2   0    0
If it is an NTFS-filesystem it looks like this:
UUID=077BBEE22CCA2110       /home/minsky/mydata     ntfs  rw,user,noauto,uid=0,gid=46,umask=007,nls=utf8                  0   0
(replace the example-UUID with the UUID of the f2fs or NTFS-partition)
