The Problem
So, this was my first time doing this. I prepared the bootable pendrive, followed the steps of installation and saw everything working fine using the preview feature, with the correct resolution: 1920x1080. The problem is: after i properly installed Ubuntu and rebooted my PC, the screen resolution dropped to 640x480 and the options to change that back are not available in the configs.
I’ve attempted finding a solution on my own, but everything I tried to do didn’t work and/or made things worse, to the point where it would not boot and I had to reinstall it. I decided, then, to look for help and ask a question here.
Thanks in advance!
More information
- Motherboard: Gigabyte Ga-78lmt-s2 Am3 Am3+ Fx 4100-Fx 8370e
- Graphic card: NVIDIA GeForce GTX 550 Ti
Running xrandr returns:
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 480, current 640 x 480, maximum 640 x 480
default connected primary 640x480+0+0 0mm x 0mm
640x480 73.00*
Running inxi -G returns:
Graphics:
Device-1: NVIDIA GF116 [Geforce GTX 550 Ti] driver: N/A
Display: x11 server: X.Org 1.20.13 driver: fbdev,nouveau
unloaded: modesetting,vesa resolution: 640x480~73Hz
OpenGL: renderer: llvmpipe (LLVM 12.0.0 256 bits) v: 4.5 Mesa 21.0.3
Things i've tried
Solutions from https://snawarhussain.com/blog/ubuntu/linux/troubleshoot/ubuntu-20.04-resolution-stuck-at-1280-x-720/ alongside with Failed to get size of gamma for output default when trying to add new screen resolution.
xrandr: Failed to get size of gamma for output default still haunts.
- Edit_1:
https://davidtsadler.com/posts/linux/2021-06-05/xrandr-failed-to-get-size-of-gamma-for-output-default/ also couldn't solve it for me. It does not seem to be what is causing my problem, since my
GRUB_CMDLINE_LINUX_DEFAULTis already set to"quiet splash"from beggining.
