I'm trying to install musikcube on focal. It complains about not being able to install libavcodec-extra, which in turn complains about libavcodec-extra58.
When I try to manually install libavcodec-extra58, I get a large list of things to remove, which can't be right:
The following packages were automatically installed and are no longer required:
glib-networking:i386 gstreamer1.0-plugins-base:i386 gstreamer1.0-plugins-good:i386 gstreamer1.0-x:i386 libaa1:i386 libaom0:i386 libasn1-8-heimdal:i386 libavahi-client3:i386
libavahi-common-data:i386 libavahi-common3:i386 libavc1394-0:i386 libavutil56:i386 libbrotli1:i386 libcaca0:i386 libcairo-gobject2:i386 libcairo2:i386 libcap2:i386
libcapi20-3:i386 libcdparanoia0:i386 libcodec2-0.9:i386 libcups2:i386 libcurl3-gnutls:i386 libdatrie1:i386 libdv4:i386 libexif12:i386 libfontconfig1:i386 libfreetype6:i386
libfribidi0:i386 libgd3:i386 libgdbm-compat4:i386 libgdbm6:i386 libgdk-pixbuf2.0-0:i386 libglib2.0-0:i386 libglu1-mesa:i386 libgmp10:i386 libgnutls30:i386 libgomp1:i386
libgphoto2-6:i386 libgphoto2-port12:i386 libgraphite2-3:i386 libgsm1:i386 libgssapi-krb5-2:i386 libgssapi3-heimdal:i386 libgstreamer-plugins-base1.0-0:i386
libgstreamer-plugins-good1.0-0:i386 libgstreamer1.0-0:i386 libgudev-1.0-0:i386 libharfbuzz0b:i386 libhcrypto4-heimdal:i386 libheimbase1-heimdal:i386
libheimntlm0-heimdal:i386 libhogweed5:i386 libhx509-5-heimdal:i386 libicu66:i386 libiec61883-0:i386 libieee1284-3:i386 libjbig0:i386 libjpeg-turbo8:i386 libjpeg8:i386
libk5crypto3:i386 libkeyutils1:i386 libkrb5-26-heimdal:i386 libkrb5-3:i386 libkrb5support0:i386 liblcms2-2:i386 libldap-2.4-2:i386 libltdl7:i386 libmp3lame0:i386
libmpg123-0:i386 libmysqlclient21:i386 libnettle7:i386 libnghttp2-14:i386 libnuma1:i386 libodbc1:i386 libopenal1:i386 libopenjp2-7:i386 libopus0:i386 liborc-0.4-0:i386
libosmesa6:i386 libp11-kit0:i386 libpango-1.0-0:i386 libpangocairo-1.0-0:i386 libpangoft2-1.0-0:i386 libpcap0.8:i386 libpci3:i386 libperl5.30:i386 libpixman-1-0:i386
libpng16-16:i386 libproxy1v5:i386 libpsl5:i386 libraw1394-11:i386 libroken18-heimdal:i386 librsvg2-2:i386 librsvg2-common:i386 librtmp1:i386 libsane:i386 libsasl2-2:i386
libsasl2-modules:i386 libsasl2-modules-db:i386 libsdl2-2.0-0:i386 libshine3:i386 libshout3:i386 libslang2:i386 libsnappy1v5:i386 libsndio7.0:i386 libsnmp35:i386
libsoup2.4-1:i386 libsoxr0:i386 libspeex1:i386 libsqlite3-0:i386 libssh-4:i386 libssl1.1:i386 libstb0:i386 libswresample3:i386 libtag1v5:i386 libtag1v5-vanilla:i386
libtasn1-6:i386 libthai0:i386 libtheora0:i386 libtiff5:i386 libtwolame0:i386 libusb-1.0-0:i386 libv4l-0:i386 libv4lconvert0:i386 libva-drm2:i386 libva-x11-2:i386
libvdpau1:i386 libvisual-0.4-0:i386 libvkd3d1:i386 libvpx6:i386 libwavpack1:i386 libwayland-cursor0:i386 libwayland-egl1:i386 libwebp6:i386 libwebpmux3:i386
libwind0-heimdal:i386 libx264-155:i386 libx265-179:i386 libxcb-render0:i386 libxcomposite1:i386 libxcursor1:i386 libxdamage1:i386 libxi6:i386 libxkbcommon0:i386
libxml2:i386 libxpm4:i386 libxrandr2:i386 libxrender1:i386 libxslt1.1:i386 libxv1:i386 libxvidcore4:i386 libzvbi0:i386 mesa-vdpau-drivers:i386 ocl-icd-libopencl1:i386
vdpau-driver-all:i386
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libvo-amrwbenc0
The following packages will be REMOVED
libavcodec58 libavcodec58:i386 libfaudio0:i386 libwine:i386 wine32:i386
The following NEW packages will be installed
libavcodec-extra58 libvo-amrwbenc0
0 to upgrade, 2 to newly install, 5 to remove and 25 not to upgrade.
Note that if I run apt autoremove normally, there is nothing to remove - the large list of autoremoveable packages is a direct result of running this command. What is further surprising about this output is that it wants to remove libavcodec58, despite the fact that libavcodec-extra58 explicitly provides libavcodec58.
apt show libavcodec-extra58 gives:
Package: libavcodec-extra58
Version: 7:4.2.4-1ubuntu0.1
Priority: optional
Section: universe/libs
Source: ffmpeg
Origin: Ubuntu
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Original-Maintainer: Debian Multimedia Maintainers <debian-multimedia@lists.debian.org>
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Installed-Size: 14.6 MB
Provides: libavcodec58 (= 7:4.2.4-1ubuntu0.1)
Depends: libaom0 (>= 1.0.0), libaribb24-0 (>= 1.0.3), libavutil56 (= 7:4.2.4-1ubuntu0.1), libc6 (>= 2.29), libcairo2 (>= 1.2.4), libcodec2-0.9, libglib2.0-0 (>= 2.12.0), libgsm1 (>= 1.0.18), liblzma5 (>= 5.1.1alpha+20120614), libmp3lame0 (>= 3.100), libopencore-amrnb0 (>= 0.1.5), libopencore-amrwb0 (>= 0.1.5), libopenjp2-7 (>= 2.0.0), libopus0 (>= 1.1), librsvg2-2 (>= 2.14.4), libshine3 (>= 3.1.0), libsnappy1v5 (>= 1.1.8), libspeex1 (>= 1.2~beta3-1), libswresample3 (= 7:4.2.4-1ubuntu0.1), libtheora0 (>= 1.0), libtwolame0 (>= 0.3.10), libva2 (>= 2.2.0), libvo-amrwbenc0 (>= 0.1.3), libvorbis0a (>= 1.1.2), libvorbisenc2 (>= 1.1.2), libvpx6 (>= 1.6.0), libwavpack1 (>= 4.40.0), libwebp6 (>= 0.5.1), libwebpmux3 (>= 0.6.1-2), libx264-155, libx265-179 (>= 3.2), libxvidcore4 (>= 1.2.2), libzvbi0 (>= 0.2.35), zlib1g (>= 1:1.2.0)
Conflicts: libavcodec58
Homepage: https://ffmpeg.org/
Download-Size: 4,880 kB
APT-Sources: http://gb.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
Description: FFmpeg library with additional de/encoders for audio/video codecs
FFmpeg is the leading multimedia framework, able to decode, encode, transcode,
mux, demux, stream, filter and play pretty much anything that humans and
machines have created. It supports the most obscure ancient formats up to the
cutting edge.
This library provides a generic encoding/decoding framework and
contains multiple decoders and encoders for audio, video and subtitle streams,
and several bitstream filters.
The shared architecture provides various services ranging from bit stream I/O
to DSP optimizations, and makes it suitable for implementing robust and fast
codecs as well as for experimentation.
This package replaces the libavcodec58 package and contains the
following additional codecs:
* ARIB STD-B24 Captions (Subtitle Decoder)
* OpenCORE Adaptive Multi-Rate (AMR) Narrow-Band (Encoder/Decoder)
* OpenCORE Adaptive Multi-Rate (AMR) Wide-Band (Decoder)
* Android VisualOn Adaptive Multi-Rate (AMR) Wide-Band (Encoder)
Because this package links against libraries that are licensed under
Apache License 2.0, the resulting binaries are distributed under the
GPL version 3 or later.
Something is broken here. The question is, what is broken? And, is it on my end (and thus fixable), or is this the fault of the package maintainers?
