I recently installed Ubuntu and I am new to it. Now I wanted to program with Visual Code but the problem is I can't download it. I tried sudo apt install ./<file>.deb (with my file path of course) but I only get this Error:
 code:amd64 : Depends: libnss3:amd64 (>= 2:3.26) but it is not installable
              Depends: apt:amd64 but it is not installable
              Depends: libxkbfile1:amd64 but it is not installable
              Depends: libsecret-1-0:amd64 but it is not installable
              Depends: libgtk-3-0:amd64 (>= 3.10.0) but it is not installable
              Depends: libxss1:amd64 but it is not installable
              Depends: libgbm1:amd64 but it is not installable
I also had a lot of problems with installing anything including changing the keyboards layout.
I'm on a M1 MacBook and using Parallels Desktop.
Output of sudo apt update:
Hit:1 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
Hit:3 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Hit:5 https://packages.microsoft.com/repos/vscode stable InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
Output of sudo apt -f install:
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
No output for dpkg --get-selections | grep hold
I appreciate any help.
N0rbert
  • 103,263
Frezoki
  • 23
M1 is ARM, so you can't install amd64 packages here.
But you can try installing VSCodium for ARM from https://github.com/VSCodium/vscodium/releases using one of the following commands (depending on CPU arch):
cd ~/Downloads
# 32-bit
wget -c https://github.com/VSCodium/vscodium/releases/download/1.63.2/codium_1.63.2-1639700511_armhf.deb
sudo apt-get install ./codium_1.63.2-1639700511_armhf.deb
64-bit
wget -c https://github.com/VSCodium/vscodium/releases/download/1.63.2/codium_1.63.2-1639700587_arm64.deb sudo apt-get install ./codium_1.63.2-1639700587_arm64.deb
N0rbert
  • 103,263
