I have an Intel 7265 wireless adapter. Doing a bit of research I've run several lines in the terminal and now lspci -knn | grep Net -A3; rfkill list gives:
    DeviceName: Intel Dual BandWireless-AC 7265 802.11 ac 1x1 WiFi + BT 4.0 Combo Adapter
    Subsystem: Intel Corporation Dual Band Wireless-AC 7265 [8086:5010]
    Kernel driver in use: iwlwifi
0: hci0: Bluetooth
    Soft blocked: yes
    Hard blocked: no
1: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
Network manager shows all networks in range. When I try to connect it prompts for the password, I enter it and it keeps asking for it until it stops trying to connect after a minute or two. I made sure the password is correct.
If I observe the connected devices my router shows while Network Manager tries to connect, I can see my laptop appears for a couple of seconds, disappears and repeats the cycle for the duration of the "Connecting" phase.
I followed this answer with no luck.
Update 1: sudo dmesg | grep -e wlo1 -e Network gives this.
