I'm using ubuntu 20.04 on Vmware virtual machine and it was working fine.
By mistake, I have executed the below command.
sudo apt purge python3.8
After that, I observed weird behavior on Virtual ubuntu So, I restarted the VM. From this point, Vm is not able to switch to GUI mode it always sticks to the TTY terminal. I can create the new VM but I setup the lots of things on that.
Please let me know the solution to my problem as soon as possible.
mchid
  • 44,904
  • 102
  • 162
A lot of system components got removed when you removed python. Never mess up with the default version of python in Ubuntu.
First, re-install python.
sudo apt install --reinstall python3
Then, reinstall the necessary packages for GUI.
sudo apt install ubuntu-desktop
Finally, reboot the computer with the command sudo reboot, and you should be greeted with the GUI.
mchid
  • 44,904
  • 102
  • 162
