after installation of ubuntu 20.04 on my old asus (x550vb) laptop my bluetooth is not working. I have dualboot with windows and bluetooth is working fine there. What I found that bluetooth package http://ppa.launchpad.net/bluetooth/bluez/ubuntu is not available for ubuntu focal. I tried to switch to apt bionic packages but it doesn't seems to work.
sudo /etc/init.d/bluetooth status
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
Jan 06 15:36:02 guliver-X550VB systemd[1]: Condition check resulted in Bluetooth service being skipped.
When I try to restart bluetooth service it shows status OK but not every time. Sometimes this doesn't happen and it remain inactive.
dmesg | grep -i blue
[ 94.282665] Bluetooth: Core ver 2.22
[ 94.282706] Bluetooth: HCI device and connection manager initialized
[ 94.282711] Bluetooth: HCI socket layer initialized
[ 94.282713] Bluetooth: L2CAP socket layer initialized
[ 94.282718] Bluetooth: SCO socket layer initialized
[ 1949.711304] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1949.711310] Bluetooth: BNEP filters: protocol multicast
[ 1949.711315] Bluetooth: BNEP socket layer initialized
It also seems that Bluetooth is not found with command below. I don't understand why.
sudo rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
I found solutions that include installing blueman but the installation is failing. I also tried to install python3.7 (also python3.6) and change system python priority to older version with command sudo update-alternatives --config python3 but this didn't help.
apt-get install blueman
blueman : Depends: python3 (< 3.7) but 3.8.2-0ubuntu2 is to be installed
What could solve this problem? Cheers!
Upates:
bluetooth device vendor (combined wifi/bt chip)
lspci -knn | grep Net -A2; lsusb
03:00.0 Network controller [0280]: MEDIATEK Corp. MT7630e 802.11bgn Wireless Network Adapter [14c3:7630]
Subsystem: Foxconn International, Inc. MT7630e 802.11bgn Wireless Network Adapter [105b:e074]
Kernel driver in use: mt76x0e
Kernel modules: mt76x0e
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 04f2:b40a Chicony Electronics Co., Ltd
Bus 001 Device 003: ID 0489:e069 Foxconn / Hon Hai
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 145f:0263 Trust Trust Wireless Mouse
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
apt-cache policy blueman python3 bluez bluetooth (BEFORE restoration of the default repositories)
blueman:
Installed: (none)
Candidate: 2.0.5-1ubuntu1.1
Version table:
2.0.5-1ubuntu1.1 500
500 http://at.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
2.0.5-1ubuntu1 500
500 http://at.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
python3:
Installed: 3.8.2-0ubuntu2
Candidate: 3.8.2-0ubuntu2
Version table:
*** 3.8.2-0ubuntu2 100
100 /var/lib/dpkg/status
3.6.7-1~18.04 500
500 http://at.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages
3.6.5-3 500
500 http://at.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
bluez:
Installed: 5.53-0ubuntu3.4
Candidate: 5.53-0ubuntu3.4
Version table:
*** 5.53-0ubuntu3.4 100
5.48-0ubuntu3.7 500
500 http://security.ubuntu.com/ubuntu bionic-security/main amd64 Packages
5.48-0ubuntu3 500
bluetooth:
Version table:
5.48-0ubuntu3.7 500
500 http://at.archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages
500 http://security.ubuntu.com/ubuntu bionic-security/universe i386 Packages
5.48-0ubuntu3 500
500 http://at.archive.ubuntu.com/ubuntu bionic/universe i386 Packages
apt-cache policy blueman python3 bluez bluetooth (AFTER restoration of the default repositories)
blueman:
Installed: 2.1.2-1
Candidate: 2.1.2-1
Version table:
*** 2.1.2-1 500
500 http://cz.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
python3:
Version table:
*** 3.8.2-0ubuntu2 500
500 http://cz.archive.ubuntu.com/ubuntu focal/main amd64 Packages
bluez:
Version table:
5.53-0ubuntu3 500
bluetooth:
Version table:
5.53-0ubuntu3 500
500 http://cz.archive.ubuntu.com/ubuntu focal/universe i386 Packages
I managed to install blueman (thanks for the suggestion). But bluetooth still does not work due to "No adapter found/missing". I tried to enable bluetooth manager but it fails, see logs below. Also bluetooth service daemon is running without any errors.
blueman-manager
blueman-manager version 2.1.2 starting
blueman-manager 12.11.38 ERROR Manager:118 on_dbus_name_appeared: Default adapter not found, trying first available.
blueman-manager 12.11.38 ERROR Manager:122 on_dbus_name_appeared: No adapter(s) found, exiting
sudo bluetoothctl devices
No default controller available
systemctl status bluetooth
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor pre>
Active: active (running) since Fri 2022-01-07 12:21:16 CET; 4min 46s ago
Main PID: 1203 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 9331)
Memory: 1.5M
CGroup: /system.slice/bluetooth.service
└─1203 /usr/lib/bluetooth/bluetoothd
Jan 07 12:21:16 guliver-X550VB systemd[1]: Starting Bluetooth service...
Jan 07 12:21:16 guliver-X550VB bluetoothd[1203]: Bluetooth daemon 5.53
Jan 07 12:21:16 guliver-X550VB bluetoothd[1203]: Starting SDP server
Jan 07 12:21:16 guliver-X550VB systemd[1]: Started Bluetooth service.
Jan 07 12:21:16 guliver-X550VB bluetoothd[1203]: Bluetooth management interface>
dmesg | grep -i firmware
Does the Firmware Bug mean I need different firmware in order to make bluetooth work?
[ 0.161743] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.317209] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 2.308933] psmouse serio4: elantech: assuming hardware version 4 (with firmware version 0x361f03)
[ 12.916805] mt76x0e 0000:03:00.0: Firmware Version: 1.0.07
