I am facing this error on a Dell Latitude E6540:
dpkg: error processing package amdgpu (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Errors were encountered while processing: amdgpu-dkms amdgpu E: Sub-process /usr/bin/dpkg returned an error code (1)
How can I fix this?
Error404
  • 8,278
  • 35
  • 60
As I mentioned in the comments, my previous answer to this question will fix this issue.
amdgpu and amdgpu-dkms are the problematic packages here because they are either not fully installed or corrupted.
Follow the below steps to fix this issue:
  1. Purge the problematic packages:
    sudo dpkg -P amdgpu && sudo dpkg -P amdgpu-dkms
    More likely this will work! But sometimes it returns the same error.
  2. In that case, you must manually delete it by running the following:
    sudo mv /var/lib/dpkg/info/amdgpu* /tmp
    This will move all the components of the package you listed to the /tmp directory. You can later remove them if you want.
  3. Then run these commands to update the repositories:
    sudo apt -f install
    sudo apt clean
    sudo apt autoremove
    sudo apt update
    sudo apt upgrade -y
Feel free to ask me any questions in the comments.
Good Luck!
Error404
  • 8,278
  • 35
  • 60
