I am setting up a simple Ubuntu machine on a KVM switch. One of the monitors is on this switch and the other is not. I want the KVM switch to always be the primary display, even when it is connected to my other computer (appears as completely disconnected to Ubuntu). Ideally I would like for it to just stop detecting changes to the monitor configuration. I have found some commands with xrandr that should solve my issue but none of them seem to work with Ubuntu 20.04 (for example:gsettings set org.gnome.settings-daemon.plugins.xrandr active false and others with different schemas). Let me know if I was even close with xrandr or if there is a better solution I could learn about.
Asked
Active
Viewed 1,308 times
This problem is at a lower level.
What is your GPU? I suspect it's an AMD GPU.
If that's the case you can fix it by disabling amdgpu.dc at boot time which will prevent the GPU from knowing when your "monitor" is turned off.
However this fix won't work for newer cards (e.g. RDNA2) since they need DC to be on.
The ticket tracking this bug is in https://gitlab.freedesktop.org/drm/amd/-/issues/461
Another possible workaround is to use the HDMI port, since this issue mostly pertains to DisplayPort ports (AFAIK).
Matias N Goldberg
- 1,179
