22
I have successfully setup WSL on my Windows 10. I have also successfully downloaded and installed Python3. However, I am unable to get pip. How do I get pip?
gyu@LAPTOP-PR3:/mnt/c/Windows/system32$ python3 --version
Python 3.8.2
gyu@LAPTOP-PR3:/mnt/c/Windows/system32$ python3 -m pip list
/usr/bin/python3: No module named pip
gyu@LAPTOP-PR3:/mnt/c/Windows/system32$ sudo apt-get install python3-pip
Reading package lists... Done
Building dependency tree
Package python3-pip is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python3-pip' has no installation candidate gyu@LAPTOP-PR3:/mnt/c/Windows/system32$ sudo apt-get install python-pip Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package python-pip
EDIT:
Here is the output from the sudo apt-get update
Err:1 http://archive.ubuntu.com/ubuntu focal InRelease
  Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out
Err:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Err:3 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Err:4 http://security.ubuntu.com/ubuntu focal-security InRelease
  Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to security.ubuntu.com:80 (91.189.88.152), connection timed out Could not connect to security.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease  Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease  Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable)
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease  Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable)
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/focal-security/InRelease  Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to security.ubuntu.com:80 (91.189.88.152), connection timed out Could not connect to security.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
Run sudo apt-get update after that Run sudo apt install python3-pip it will install a lot of missing components... and python pip is installed.
Frankthetank
  • 371
Are you using a proxy? I had the same issue and did the following steps: Configure Proxy Settings in WSL: You need to configure WSL to use your proxy server. You can do this by setting the http_proxy and https_proxy environment variables within WSL.
Open your .bashrc file in WSL using a text editor:
vim ~/.bashrc Add the following lines at the end of the file:
export http_proxy="http://<proxy_ip>:<proxy_port>"
export https_proxy="http://<proxy_ip>:<proxy_port>" Replace <proxy_ip> and <proxy_port> with the IP address and port of your proxy server.
Save the file and exit the editor. Then, apply the changes by running:
source ~/.bashrc Update APT Configuration: You also need to configure APT to use the proxy settings. Edit the APT configuration file:
sudo vim /etc/apt/apt.conf Add the following line to the file:
Acquire::http::Proxy "http://<proxy_ip>:<proxy_port>/"; Replace <proxy_ip> and <proxy_port> with the IP address and port of your proxy server.
