-2
I tried to update Ubuntu 20.04 after a long while, and it failed due to some MySQL error. I searched the web and the suggested answer was rm mysql directories. I did that, but it still did not solve the problem.
I tried dpkg --remove --force-all mysql-server-8.0, but it says:
Unit mysql.service could not be found. dpkg: error while cleaning up:
...post-installation script subprocess returned error
apt purge/upgrade/remove fails with
The package mysql-server-8.0 needs to be reinstalled
I don't remember installing MySQL, but even if I did, I don't need MySQL. I don't care about it at all. How can I completely nuke MySQL and get apt working again?
test@ubuntu:~$ sudo apt install --reinstall mysql-server-8.0
Reading package lists... Done
Building dependency tree
E: The package mysql-server-8.0 needs to be reinstalled, but an archive for it can't be found.
test@ubuntu: $ sudo apt purge mysql-server-8.0
test@ubuntu:~$ sudo apt install mysql-server --reinstall
~$ sudo apt purge mysql-server-core-8.0 -f
The following packages were automatically installed and are no longer required:
  galera-3 libaio1 libcgi-fast-perl libcgi-pm-perl libconfig-inifiles-perl
  libevent-core-2.1-7 libevent-pthreads-2.1-7 libfcgi-perl
  libhtml-template-perl libllvm10 libllvm11 libmecab2 libreadline5
  libterm-readkey-perl linux-headers-5.4.0-42 linux-headers-5.4.0-42-generic
  linux-image-5.4.0-42-generic linux-modules-5.4.0-42-generic
  linux-modules-extra-5.4.0-42-generic mecab-ipadic mecab-ipadic-utf8
  mecab-utils socat
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED
  mysql-server-8.0* mysql-server-core-8.0*
0 to upgrade, 0 to newly install, 2 to remove and 3 not to upgrade.
1 not fully installed or removed.
After this operation, 137 MB disk space will be freed.
Do you want to continue? [Y/n]
dpkg: error processing package mysql-server-8.0 (--remove):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting a removal
dpkg: too many errors, stopping
 mysql-server-8.0
Processing was halted because there were too many errors.
and
$ sudo dpkg -i --force-all mysql-server-8.0_8.0.27-0ubuntu0.20.04.1_amd64.deb
(Reading database ... 471728 files and directories currently installed.)
Preparing to unpack mysql-server-8.0_8.0.27-0ubuntu0.20.04.1_amd64.deb ...
Failed to stop mysql.service: Unit mysql.service not loaded.
invoke-rc.d: initscript mysql, action "stop" failed.
dpkg: warning: old mysql-server-8.0 package pre-removal script subprocess returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: error processing archive mysql-server-8.0_8.0.27-0ubuntu0.20.04.1_amd64.deb (--install):
 new mysql-server-8.0 package pre-removal script subprocess returned error exit status 1
Failed to preset unit: File mysql.service: Link has been severed
/usr/bin/deb-systemd-helper: error: systemctl preset failed on mysql.service: No such file or directory
Failed to start mysql.service: Unit mysql.service not found.
invoke-rc.d: initscript mysql, action "start" failed.
 installed mysql-server-8.0 package post-installation script subprocess returned error exit status 1
If you cannot find an archive for Mysql then try manually installing the archive.
First, Try if downloading the deb file works:
sudo apt download mysql-server-8.0
Now, using dpkg compile the archive:
sudo dpkg -i --force-all ./*.deb
If the above didn't work then try:
First, click here, and a deb file will start downloading.
After that use the dpkg -i command to install the .deb file.
I am not sure but you can also run the following command to download the deb and install it:
wget https://dev.mysql.com/get/mysql-apt-config_0.8.20-1_all.deb && sudo dpkg -i *.deb
After, running the above:
sudo apt install mysql-server-8.0
If the above didn't work then purge MySQL:
sudo dpkg -P mysql*
Here is another way to remove MySQL:
sudo mv /var/lib/dpkg/info/mysql* ~/ && sudo apt -f install
If the above all didn't work then one last thing to try is:
First, change the contents of /etc/apt/sources.list to:
deb http://archive.ubuntu.com/ubuntu/ focal main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ focal main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ focal-updates main restricted universe multiverse deb-src http://archive.ubuntu.com/ubuntu/ focal-updates main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse deb-src http://archive.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse deb-src http://archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
deb http://archive.canonical.com/ubuntu focal partner deb-src http://archive.canonical.com/ubuntu focal partner
And run apt update followed by:
If that also didn't worked then
If the above didn't work then I'll recommend reinstalling Ubuntu.
Error404
  • 8,278
  • 35
  • 60
