163
Currently when I execute the date command from bash I get the following displayed
Thu May 17 12:21:00 IST 2012
Below is my timezone config based on executing dpkg-reconfigure tzdata
  Current default time zone: 'Europe/Dublin'
  Local time is now: Thu May 17 12:32:52 IST 2012.
  Universal Time is now: Thu May 17 11:32:52 UTC 2012.
Any idea how I change from IST to UTC/GMT?
muru
  • 207,228
dmckenna
  • 1,733
7 Answers7
208
Any idea how I change from IST to GMT?
To switch to UTC, simply execute sudo dpkg-reconfigure tzdata, scroll to the bottom of the Continents list and select Etc or None of the above; in the second list, select UTC. If you prefer GMT instead of UTC, it's just above UTC in that list. :)
ish
  • 141,990
99
sudo timedatectl set-timezone UTC
Will change your timezone to UTC system wide.
You can do timedatectl list-timezones to see all the available timezones.
excerpt from @MattJohnson's answer on SO
Zones like Etc/GMT+6 are intentionally reversed for backwards compatibility with POSIX standards. See the comments in this file.
You should almost never need to use these zones. Instead you should be using a fully named time zone like America/New_York or Europe/London or whatever is appropriate for your location. Refer to the list here.
abu_bua
  • 11,313
dkam
  • 1,109
In the old Un*x style (SunOS, HPUX...), you can do:
ln -fs /usr/share/zoneinfo/UTC /etc/localtime
Check the contents of /usr/share/zoneinfo to get the timezone you want/need.
For instance, Irish Summer Time (IST) can be defined as
-rw-r--r-- 1 root root 3661 Mar 13 22:18 /usr/share/zoneinfo/posix/Eire
or
lrwxrwxrwx 1 root root 13 Mar 13 22:18 /usr/share/zoneinfo/Europe/Dublin -> ../posix/Eire
However, the most important is to use a proper clock reference and a ntp daemon (openntpd for instance), as timezone is only used for displaying/converting the time to strings, not to store it (whatever the timezone, difference to 01/01/1970 is everywhere the same on Earth).
12
Updated for 14.04 to present
View Time and Date Status:
$ timedatectl status
                      Local time: Sun 2018-07-29 15:26:03 BST
                  Universal time: Sun 2018-07-29 14:26:03 UTC
                        RTC time: Sun 2018-07-29 14:26:03
                       Time zone: Europe/London (BST, +0100)
       System clock synchronized: yes
systemd-timesyncd.service active: yes
                 RTC in local TZ: no
View List of Timezones:
Listed Timezones (425)
$ timedatectl list-timezones
Africa/Abidjan
Africa/Accra
Africa/Addis_Ababa
Pacific/Tongatapu
Pacific/Wake
Pacific/Wallis
UTC
Set Timezone to UTC:
$ timedatectl set-timezone UTC
                      Local time: Sun 2018-07-29 14:46:27 UTC
                  Universal time: Sun 2018-07-29 14:46:27 UTC
                        RTC time: Sun 2018-07-29 14:46:27
                       Time zone: UTC (UTC, +0000)
                 RTC in local TZ: no*
Broadsworde
  • 4,532
Something like this?
$ date
Wed Jul 16 22:52:47 EDT 2014
$ cat /etc/timezone
America/New_York
$ sudo dpkg-reconfigure tzdata
$ service cron stop && service cron start
Kerem
  • 696
In case you need this for only a single command, say, ls, use this:
TZ=UTC ls -l --full-time
When I saw that VDS TZ is wrong......
// see current TZ
# date
Wed Sep 25 16:27:14 UTC 2024
// see the current Continent/Place
cat /etc/timezone
Etc/UTC
// find out our new position
timedatectl list-timezones |grep Moscow
Europe/Moscow
// you will not be able to make a mistake in new position by this way
timedatectl list-timezones |grep Moscow |xargs timedatectl set-timezone
// ensure that position changed
cat /etc/timezone
Europe/Moscow
// the date is displayed correctly
date
Wed Sep 25 19:31:45 MSK 2024
