29
I'm trying to install chrome using the commands below:
wget -q -O - https://dl-ssl.google.com/linux/linux_signing_key.pub | apt-key add -
sh -c 'echo "deb [arch=$(dpkg --print-architecture)] https://dl-ssl.google.com/linux/chrome/deb/ stable main" >> /etc/apt/sources.list.d/google.list'
apt update && apt install -y google-chrome-stable --no-install-recommends
I get the following error:
Get:4 https://dl-ssl.google.com/linux/chrome/deb stable InRelease [1811 B]
Fetched 1811 B in 0s (4467 B/s)
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
Reading package lists... Building dependency tree... Reading state information... E: Unable to locate package google-chrome-stable
Anyone have any ideas why this doesn't work for me? Could it be that Google chrome package is not available for my system:
root@xxx:/# dpkg --print-architecture
arm64
root@xxx:/# uname -a
Linux xxxx 5.11.0-1021-oracle #22~20.04.1-Ubuntu SMP Fri Oct 22 21:42:24 UTC 2021 aarch64 GNU/Linux
root@65653cdc2f7b:/# cat /etc/debian_version 11.2
auser
  • 401
You can't and this is expected. Google Chrome is only packaged for amd64, and is not available for ARM (they do have ARM versions for Windows and Mac, though). You can use Chromium instead. It is the free and open source browser, on which Chrome is based.
You can remove the Chrome repository, and install chromium with
sudo apt install chromium-browser
This will install the snap chromium package. If you want a pure apt version, see this answer.
Google removed synchronization features from Chromium. If you need synchronization, use Firefox instead.
sudo apt install firefox
Alternatively, ask Google to release Chrome for ARM or to fix sync in Chromium, if you really need it. If you really need sync then use Firefox instead.
