I want to install Ubuntu on a third, seperate drive:
On physical drive 1 is Windows 10 and physical drive 2 is just one big partition for storage. (Windows disk manager view, drive 3 not visible as it is currently not connected yet)
Now I read many times that I should disable or unplug all other drives before installing as there is a possibilty things get a bit broken with the bootup behavior when installing with other drives connected.
The problem is: I can't disable SATA drives seperately in the BIOS.
The manaul says so but I don't have the option in the actual BIOS only to disable all SATA ports which would make it impossible to install Linux on drive 3 as it is a 2,5" SATA SSD.
Also drive 2 is a M2 drive and positioned in a way that I would have to:
Take out my GPU, then remove a protective hardcover and remove the SSD, then put back the GPU, install Linux, remove GPU, install M2, install protective cover and install GPU again.
I am fully capable of doing this myself but I don't want to if it's not absolutely necessary.
Fortunately drive 1, which contains the Windows 10 install, is a 2,5" SSD and I can easily unplug the SATA cable.
Would this be enough to be safe as drive 2 is simply a storage drive which shouldnt even have a MBR or anything concerning boot. Is this enough to safely install Ubuntu on drive 3?
Chris
