Hopefully someone can help out, I have tried pretty much everything the online resources sugested but just hit a dead end, also having entry level knowledge is making this very painful. Distributor ID: Ubuntu Description: Ubuntu 20.04.3 LTS Release: 20.04 Codename: focal
I am trying to install a package but running into below error
root@librenms03:/# sudo apt-get install ruby ruby-dev libsqlite3-dev libssl-dev pkg-config cmake libssh2-1-dev libicu-dev zlib1g-dev g++
Reading package lists... Done
Building dependency tree
g++ is already the newest version (4:9.3.0-1ubuntu2).
g++ set to manually installed.
pkg-config is already the newest version (0.29.1-0ubuntu4).
pkg-config set to manually installed.
libicu-dev : Depends: libicu66 (= 66.1-2ubuntu2) but 66.1-2ubuntu2.1 is to be installed
libssl-dev : Depends: libssl1.1 (= 1.1.1f-1ubuntu2.8) but 1.1.1f-1ubuntu2.10 is to be installed
root@librenms03:/#
there is nothing "onhold" checked tried apt-get clean && sudo apt-get update tried aptitude install libssl-dev tried numerous other things that take me nowhere.
Any help would be appriciated.
Thank you
also:
root@librenms03:~# apt policy libssl-dev
libssl-dev:
Installed: (none)
Candidate: 1.1.1f-1ubuntu2.8
Version table:
1.1.1f-1ubuntu2.8 500
500 http://mirror01.name.com/ubuntu/current focal-updates/main amd64 Packages
500 http://mirror01.name.com/ubuntu/current focal-security/main amd64 Packages
1.1.1f-1ubuntu2 500
500 http://mirror01.name.com/ubuntu/current focal/main amd64 Packages
root@librenms03:~
