Upon installing a software, I am finding the following error multiple times:
$ sudo python setup.py install
Traceback (most recent call last):
  File "setup.py", line 24, in <module>
    from software_name import PACKAGE_NAME
  File "/home/username/Softwares/software_name/__init__.py", line 29, in <module>
import scipy
ImportError: No module named scipy
I can install many of the missing modules with, e.g., sudo apt-get install -y python-numpy, but sometimes I get:
username@username:~/Softwares/software_name$ sudo apt-get install -y python-scipy
Reading package lists... Done
Building dependency tree
Package python-scipy is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python-scipy' has no installation candidate
And I am really not sure what is going on? I have read on another thread that the 20.04 LTS repository has NumPy, but does not have SciPy.
EDIT:
$ sudo apt install python-pip
Package python-pip is not available, but is referred to by another package.
However the following packages replace it:
  python3-pip
E: Package 'python-pip' has no installation candidate
$ pip install scipy Requirement already satisfied: scipy in /usr/lib/python3/dist-packages (1.3.3)
$ sudo apt install python3-pip Reading package lists... Done Building dependency tree
Reading state information... Done python3-pip is already the newest version (20.0.2-5ubuntu1.6). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ sudo pip install scipy [sudo] password for user_name: Requirement already satisfied: scipy in /usr/lib/python3/dist-packages (1.3.3)
$ python --version Python 2.7.18
Py-ser
  • 687
Best source for looking up packages in ubuntu repositories is packages.ubuntu.com
You can search for scipy and will see, that it was taken out from the universe after 18.04.
I can only speculate about the reason, maybe no maintainer for the package could be found.
However, you can easily install it via pip:
pip install scipy
Note, that pip will default to install a package to your local user. If you need to run a python script with sudo or another user, you need to install it systemwide with:
If your python still not recognize the package, you may need to check if python maybe links to python2. Check with python --version.
pLumo
  • 27,991
