I'm running 21.10 and it is very slow to start. What can I do to speed it up? Here are some output from systemd-analyze
# systemd-analyze time
Startup finished in 4.592s (kernel) + 2min 52.922s (userspace) = 2min 57.515s
graphical.target reached after 2min 52.311s in userspace
systemd-analyze critical-chain
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @2min 52.311s
└─multi-user.target @2min 52.311s
└─plymouth-quit-wait.service @1min 743ms +1min 51.566s
└─systemd-user-sessions.service @1min 338ms +214ms
└─network.target @1min 51ms
└─wpa_supplicant.service @51.897s +8.153s
└─dbus.service @49.103s
└─basic.target @49.073s
└─sockets.target @49.072s
└─cups.socket @58.292s
└─sysinit.target @48.963s
└─snapd.apparmor.service @47.673s +1.289s
└─apparmor.service @45.304s +2.366s
└─local-fs.target @45.302s
└─boot.mount @45.266s +34ms
└─systemd-fsck@dev-disk-by\x2duuid-5dff6fb3\x2d361f\x2d4666\x2d9462\x2d45f78a65ab47.service @45.001s +24>
└─dev-disk-by\x2duuid-5dff6fb3\x2d361f\x2d4666\x2d9462\x2d45f78a65ab47.device @44.999s
systemd-analyze blame
1min 51.566s plymouth-quit-wait.service
1min 9.365s man-db.service
35.323s dev-sda3.device
31.737s logrotate.service
27.427s snapd.service
25.519s networkd-dispatcher.service
19.326s cups.service
18.091s apt-daily.service
17.520s systemd-journal-flush.service
17.516s udisks2.service
15.157s ModemManager.service
12.620s NetworkManager-wait-online.service
12.069s dev-loop14.device
11.440s dev-loop11.device
11.230s dev-loop26.device
11.224s dev-loop3.device
10.977s dev-loop20.device
10.877s NetworkManager.service
10.877s avahi-daemon.service
10.803s dev-loop16.device
10.717s dev-loop9.device
10.694s dev-loop22.device
10.584s dev-loop25.device
10.550s polkit.service
10.415s accounts-daemon.service
10.317s dev-loop27.device
10.101s dev-loop18.device
9.976s dev-loop2.device
9.830s dev-loop13.device
9.816s dev-loop24.device
9.720s dev-loop23.device
9.665s power-profiles-daemon.service
9.451s dev-loop21.device
9.429s dev-loop15.device
9.224s dev-loop19.device
8.392s dev-loop12.device
8.299s dev-loop10.device
8.202s switcheroo-control.service
8.169s dev-loop17.device
8.153s wpa_supplicant.service
8.091s thermald.service
8.084s systemd-logind.service
7.972s snapd.seeded.service
7.845s dev-loop4.device
7.192s dev-loop8.device
5.923s gdm.service
5.645s dev-loop6.device
5.556s dev-loop1.device
5.166s dev-loop7.device
Any ideas?
EDIT 1: Some system info.
It has 4 cores.
vendor_id : AuthenticAMD
cpu family : 21
model : 16
model name : AMD A8-5500 APU with Radeon(tm) HD Graphics
stepping : 1
microcode : 0x6001119
cpu MHz : 1406.533
cache size : 2048 KB
12 GB ram.
There is a SSD disc in the system.
/etc/fstab
# / was on /dev/sda3 during installation
UUID=1987d431-8f81-442f-8fc1-821fc4a1283a / ext4 errors=remount-ro 0 1
# /boot was on /dev/sda1 during installation
UUID=5dff6fb3-361f-4666-9462-45f78a65ab47 /boot ext4 defaults 0 2
# swap was on /dev/sda5 during installation
UUID=a4a87e3f-9f91-40bb-baa1-3bc7b11d1f1c none swap sw 0 0
fdisk -l (skipping /dev/loop1 ... /dev/loop30)
disk /dev/sda: 298,09 GiB, 320072933376 byte, 625142448 sektorer
Disk model: WDC WD3200BEVT-2
Enheter: sektorer av 1 * 512 = 512 byte
Sektorstorlek (logisk/fysisk): 512 byte / 512 byte
I/O-storlek (minsta/optimal): 512 byte / 512 byte
Disketikettstyp: dos
Diskidentifierare: 0x64a92ab6
Enhet Start Början Slutet Sektorer Storlek Id Typ
/dev/sda1 * 2048 1953791 1951744 953M 83 Linux
/dev/sda2 1955838 17577983 15622146 7,4G 5 Utökad
/dev/sda3 17577984 625141759 607563776 289,7G 83 Linux
/dev/sda5 1955840 17577983 15622144 7,4G 82 Linux växling / Solaris
Poster i partitionstabell är inte i diskordning.
And here is blkid
/dev/sda5: UUID="a4a87e3f-9f91-40bb-baa1-3bc7b11d1f1c" TYPE="swap" PARTUUID="64a92ab6-05"
/dev/sda3: UUID="1987d431-8f81-442f-8fc1-821fc4a1283a" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="64a92ab6-03"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/sda1: UUID="5dff6fb3-361f-4666-9462-45f78a65ab47" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="64a92ab6-01"
