Can't update nor install anything for a while now, since several packages allegedly have unmet dependencies.
sudo apt-get upgrade:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
 linux-image-generic-hwe-20.04 : Depends: linux-image-5.11.0-43-generic but it is not installed
 linux-modules-extra-5.11.0-38-generic : Depends: linux-image-5.11.0-38-generic but it is not installed or
                                                  linux-image-unsigned-5.11.0-38-generic but it is not installed
 linux-modules-extra-5.11.0-40-generic : Depends: linux-image-5.11.0-40-generic but it is not installed or
                                                  linux-image-unsigned-5.11.0-40-generic but it is not installed
 linux-modules-extra-5.11.0-41-generic : Depends: linux-image-5.11.0-41-generic but it is not installed or
                                                  linux-image-unsigned-5.11.0-41-generic but it is not installed
 linux-modules-extra-5.11.0-43-generic : Depends: linux-image-5.11.0-43-generic but it is not installed or
                                                  linux-image-unsigned-5.11.0-43-generic but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
sudo apt --fix-broken install:
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  libcg libcggl libllvm12 libllvm12:i386 libmlt++3 libmlt-data libmlt6
  linux-headers-5.11.0-38-generic linux-headers-5.11.0-40-generic
  linux-headers-5.11.0-41-generic linux-hwe-5.11-headers-5.11.0-38
  linux-hwe-5.11-headers-5.11.0-40 linux-hwe-5.11-headers-5.11.0-41
  linux-image-5.11.0-38-generic linux-image-5.11.0-40-generic
  linux-image-5.11.0-41-generic linux-modules-5.11.0-38-generic
  linux-modules-5.11.0-40-generic linux-modules-5.11.0-41-generic
  linux-modules-extra-5.11.0-38-generic linux-modules-extra-5.11.0-40-generic
  linux-modules-extra-5.11.0-41-generic melt nvidia-cg-dev nvidia-cg-toolkit shim
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  linux-image-5.11.0-41-generic linux-image-5.11.0-43-generic
  linux-modules-5.11.0-38-generic linux-modules-5.11.0-40-generic
  linux-modules-5.11.0-41-generic linux-modules-5.11.0-43-generic
Suggested packages:
  fdutils linux-doc | linux-hwe-5.11-source-5.11.0 linux-hwe-5.11-tools
The following NEW packages will be installed:
0 upgraded, 8 newly installed, 0 to remove and 1 not upgraded.
119 not fully installed or removed.
Need to get 0 B/114 MB of archives.
After this operation, 420 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 683886 files and directories currently installed.)
Preparing to unpack .../0-linux-modules-5.11.0-43-generic_5.11.0-43.47~20.04.2_amd64.deb ...
Unpacking linux-modules-5.11.0-43-generic (5.11.0-43.47~20.04.2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-HgC93P/0-linux-modules-5.11.0-43-generic_5.11.0-43.47~20.04.2_amd64.deb (--unpack):
 cannot copy extracted data for './boot/System.map-5.11.0-43-generic' to '/boot/System.map-5.11.0-43-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
        dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Preparing to unpack .../1-linux-image-5.11.0-43-generic_5.11.0-43.47~20.04.2_amd64.deb ...
Unpacking linux-image-5.11.0-43-generic (5.11.0-43.47~20.04.2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-HgC93P/1-linux-image-5.11.0-43-generic_5.11.0-43.47~20.04.2_amd64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-5.11.0-43-generic' to '/boot/vmlinuz-5.11.0-43-generic.dpkg-new': failed to write (No space left on device)
Preparing to unpack .../2-linux-modules-5.11.0-38-generic_5.11.0-38.42~20.04.1_amd64.deb ...
Unpacking linux-modules-5.11.0-38-generic (5.11.0-38.42~20.04.1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-HgC93P/2-linux-modules-5.11.0-38-generic_5.11.0-38.42~20.04.1_amd64.deb (--unpack):
 cannot copy extracted data for './boot/System.map-5.11.0-38-generic' to '/boot/System.map-5.11.0-38-generic.dpkg-new': failed to write (No space left on device)
Preparing to unpack .../3-linux-image-5.11.0-38-generic_5.11.0-38.42~20.04.1_amd64.deb ...
Unpacking linux-image-5.11.0-38-generic (5.11.0-38.42~20.04.1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-HgC93P/3-linux-image-5.11.0-38-generic_5.11.0-38.42~20.04.1_amd64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-5.11.0-38-generic' to '/boot/vmlinuz-5.11.0-38-generic.dpkg-new': failed to write (No space left on device)
No apport report written because MaxReports is reached already
Preparing to unpack .../4-linux-modules-5.11.0-40-generic_5.11.0-40.44~20.04.2_amd64.deb ...
Unpacking linux-modules-5.11.0-40-generic (5.11.0-40.44~20.04.2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-HgC93P/4-linux-modules-5.11.0-40-generic_5.11.0-40.44~20.04.2_amd64.deb (--unpack):
 cannot copy extracted data for './boot/System.map-5.11.0-40-generic' to '/boot/System.map-5.11.0-40-generic.dpkg-new': failed to write (No space left on device)
Preparing to unpack .../5-linux-image-5.11.0-40-generic_5.11.0-40.44~20.04.2_amd64.deb ...
Unpacking linux-image-5.11.0-40-generic (5.11.0-40.44~20.04.2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-HgC93P/5-linux-image-5.11.0-40-generic_5.11.0-40.44~20.04.2_amd64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-5.11.0-40-generic' to '/boot/vmlinuz-5.11.0-40-generic.dpkg-new': failed to write (No space left on device)
Preparing to unpack .../6-linux-modules-5.11.0-41-generic_5.11.0-41.45~20.04.1_amd64.deb ...
Unpacking linux-modules-5.11.0-41-generic (5.11.0-41.45~20.04.1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-HgC93P/6-linux-modules-5.11.0-41-generic_5.11.0-41.45~20.04.1_amd64.deb (--unpack):
 cannot copy extracted data for './boot/System.map-5.11.0-41-generic' to '/boot/System.map-5.11.0-41-generic.dpkg-new': failed to write (No space left on device)
Preparing to unpack .../7-linux-image-5.11.0-41-generic_5.11.0-41.45~20.04.1_amd64.deb ...
Unpacking linux-image-5.11.0-41-generic (5.11.0-41.45~20.04.1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-HgC93P/7-linux-image-5.11.0-41-generic_5.11.0-41.45~20.04.1_amd64.deb (--unpack):
 cannot copy extracted data for './boot/vmlinuz-5.11.0-41-generic' to '/boot/vmlinuz-5.11.0-41-generic.dpkg-new': failed to write (No space left on device)
I would really appreciate if You could help. Thank you! ^^
jokyjoe
  • 23
The error is error message indicates a disk full error
  1. check current kernal version by : uname -a
  2. cd /boot
  3. ls -al
  4. try del the files which version is not current kernal version .
  5. try 'sudo apt-get autoremove'
  6. try sudo apt --fix-broken install
  7. try sudo apt-get update
  8. try sudo apt-get upgrade
Tom
  • 136
