I'm new to Ubuntu having moved from hosting on CentOS7 which was using iptables and I was comfortable with how apf and bfd handled (hid) iptables from me.. and it was working well
So, I've moved to Ubuntu (20.04 LSR) and the "ubuntu-way" to do firewall with auto banning attempts to break in appears to be nftables and fail2ban
I used iRedMail to set up a basic nginx, postfix, dovecot, clamav, roundcube etc.. based mail server and it configured fail2ban to watch the the logs for attempts at hacking into the mail services and ssh etc.. and I've seen it correctly parse my mail logs and store the fial2ban blocked ips in table inet f2b-table
This properly survives reboot but I noticed that the /etc/nftables.conf file does not have any of the fail2ban tables in it - it's got my base firewall which I am able to statically update to deny all then unblock tcp ports I want (basically mail and web server and ssh)
But as far as I can see, the fail2ban rules are not in a config file but seem to be reconstructed on boot from entries in a fail2ban table in a mysql database set up by iRedMail
This is fine..but here's the dilemma: if I manually add a rule to the firewall taking advantage of the existing table for fail2ban I can..
nft add element inet f2b-table addr-set-postfix-pregreet { spammer.ip.addr.here }
It shows up and works.. I tested by successfully locking myself out then removed via local console..
Except when I reboot, that entire table is lost and rebuilt by fail2ban from the table entries (again I'm cool with that)
So, I went ahead and added my own new table/stuff
table inet spammers {
set blackhole {
type ipv4_addr
elements = { sample.ip.addr.here }
chain spammers-chain {
type filter hook input priority filter - 2; policy accept;
ip saddr @blackhole drop
Again, tested this and it works well but in order to persist this out I need to write it to /etc/nftables.conf or set up that directory to read in my rules etc..
I could do this by adding an include in my nftables.conf to a directory of arbitrary rules and then store my table out to it every time I add an address but this seems ugly and wrong
as in if I want to add a new spammer to my list I can do
nft add element inet spammers blackhole { new.ip.addr.here }
but then would need to .. I dunno? persist out the table to my file?
nft list table inet spammers > /etc/nftables.d/spammers.conf
So, that's one way I could do it, but I've seen others talk about netfilter-persist but that's not part of Ubuntu so before I go off either inventing my own wheel or down the netfilter-persist rabbit hole or (no thanks) do something akin to what fail2ban seems to have done... (storing the banned IPs in a database and reconstructing the list at login)
I can come up with several ways I could do this.. but I was wondering if there was a "best practice" "Ubuntu-way" I am missing here...
UPDATE/EDIT: Unless I get a better suggestion, my "solution" for now is
mkdir /etc/nftables.d/
and then I edited my /etc/nftables.conf to add this line at the bottom
include "/etc/nftables.d/*.conf"
Now, when I add a block to the table it's 2 steps:
nft add element inet spammers blackhole { some.evildoer.ip.address }
It's not the prettiest but it absolutely works.. I could of course wrap this all in my own custom script so I could jsut call something like
banspammer "badguy.ip.addr.here"
and banspammer would add the address element specified and save out the updated table def...
again, this just feels like "not a best practice" hence my question.
EDIT: 2021-12-22 OK so I'm kind of talking to myself but since I haven't gotten any feedback I went with my idea - it's working and I wrote this little banspammer script... it's raw and probably highly dangerous - I didn't do sanity checks like bothering to check if the config file path is valid and didn't do any backing up of said file etc...
Since the table entry is a type ipv4_addr nftables does validation so I don't worry too much about that
NOTE that my particular setup already had a fileter named filter in teh inet family - I specifically add this as a slightly lower priority list I also created the /etc/nftables.d directory and added in my code to have it parse the config directory as I mentioned above
here's hoping someone finds this useful.
I'd still be interested in a more "Ubuntu-way" if there was such a thing.
#!/usr/bin/sh
banspammer 2021-12-22 DigitalSorceress
SUMMARY
This script adds an ip or range of Ips (see element adding) to nftables
specifically to my spammer blackhole
it also persists it out to /etc/nftables.d/spammers.conf
put this somewhere like /root/tandautils
then go to /user/local/sbin and ln -s /root/tandautils/banspammer.sh banspammer
Handle command line args
COMMAND=$1
ADDRESS=$2
the location of the ssh daemon config file
default for CentOS is CONFIG_FILE=/etc/ssh/sshd_config
CONFIG_FILE=/etc/nftables.d/spammers.conf
Here are the subroutines for individual actions
ban_spammer () {
# Issue the basic command to ban the spammer
echo "adding spammer to blackhole ..."
nft add element inet spammers blackhole { ${ADDRESS} }
BAN_SPAMMER_RESULT=$?
if [ $BAN_SPAMMER_RESULT -eq 0 ]
then
echo " DONE: ${ADDRESS} added to spammer table"
fi
echo ""
unban_spammer () {
echo "removing spammer from blackhole ..."
nft delete element inet spammers blackhole { ${ADDRESS} }
UNBAN_SPAMMER_RESULT=$?
if [ $UNBAN_SPAMMER_RESULT -eq 0 ]
then
echo " DONE: ${ADDRESS} removed from table"
fi
echo ""
persist_spamtable () {
echo "persisting out spamtable to ${CONFIG_FILE}..."
# we need to persist out the spam table to the config
nft list table inet spammers > ${CONFIG_FILE}
if [ $? -eq 0 ]
then
echo " done.. showing table..."
echo ""
else
echo "error persisting table.. "
fi
echo ""
list_spamtable () {
echo "listing out spamtable"
echo ""
echo ""
kill_spamtable () {
echo "resetting /creating blank spamtable ${CONFIG_FILE}..."
#rm -f /etc/nftables.d/spammers.conf
tee /etc/nftables.d/spammers.conf <<EOF
set blackhole {
type ipv4_addr
EOF
echo ""
if [ $? -eq 0 ]
then
echo "success.. here's the new file:"
echo ""
cat /etc/hftables.d/spammers.conf
else
echo "error writing file... "
fi
echo ""
help_me () {
echo "This is a tool to simplify blocking of IP addesses of spammers "
echo " "
echo "banspammer 2021-12-22 DigitalSorceress"
echo " "
echo "SUMMARY "
echo " This script is used to simplify the act of adding/removing spammers from "
echo " a spammers table in the nftables ruleset "
echo " "
echo " "
echo "usage: $0 banspammer command [address] "
echo " "
echo " command options: "
echo " ban address "
echo " bans the target address; can be a singe IP or comma sep list "
echo " "
echo " unban address "
echo " removes the target address can be a singe IP or comma sep list "
echo " "
echo " reset "
echo " clears all entries from the spammers table "
echo " note this can be used to create a new empty table "
echo " "
echo " show "
echo " shows the current spam table list "
echo " "
echo " help "
echo " Displays this help dialog "
Here is where we do the actual work based on the passed command
case "$COMMAND" in
ban)
if [ $# -eq 2 ]
then
echo "banning address: ${ADDRESS}"
ban_spammer ${ADDRESS}
then
persist_spamtable
fi
else
echo "ban command requires a single IP or comma separated list of IPs "
fi
unban)
if [ $# -eq 2 ]
then
echo "unbanning address: ${ADDRESS}"
unban_spammer ${ADDRESS}
then
persist_spamtable
fi
fi
show)
list_spamtable
reset)
kill_spamtable
help)
help_me
echo "Usage: $0 ban|unban comma-separated-ip-list or $0 show|reset"
exit 1
esac
