My Dell laptop on Ubuntu 20.04 is currently getting stuck on boot after it crashed. I tried to run fsck on an Ubuntu live USB, but when I run the command on my linux filesystem partition sudo fsck -y -f /dev/nvme0n1p3 I only get the following output :
fsck from util-linux 2.34
The fdisk -l command returns 3 partitions:
/dev/nvm0n1p1 of 513M, EFI System
/dev/nvm0n1p2 of 732M, Linux Filesystem
/dev/nvm0n1p3 of 952G, Linux Filesystem
Here is the output of sudo parted -l:
Warning: The driver descriptor says the physical block size is 2048 bytes, but
Linux says it is 512 bytes.
Ignore/Cancel? I
Model: USB Flash Disk (scsi)
Disk /dev/sda: 62.1GB
Sector size (logical/physical): 2048B/512B
Partition Table: mac
Disk Flags:
Number Start End Size File system Name Flags
1 2048B 6143B 4096B Apple
2 2699MB 2703MB 4096kB EFI
Model: Linux device-mapper (linear) (dm)
Disk /dev/mapper/ubuntu--vg-root: 999GB
Sector size (logical/physical): 512B/512B
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 999GB 999GB ext4
Disk /dev/mapper/ubuntu--vg-swap_1: 1023MB
Disk Flags:
1 0.00B 1023MB 1023MB linux-swap(v1)
Error: /dev/mapper/luks-fddac026-db32-4798-9083-b5a8665f7202: unrecognised disk label
Model: Linux device-mapper (crypt) (dm)
Disk /dev/mapper/luks-fddac026-db32-4798-9083-b5a8665f7202: 1023GB
Partition Table: unknown
Disk Flags:
Model: KXG50ZNV1T02 NVMe TOSHIBA 1024GB (nvme)
Disk /dev/nvme0n1: 1024GB
Partition Table: gpt
Disk Flags:
1 1049kB 538MB 537MB fat32 EFI System Partition boot, esp
2 538MB 1305MB 768MB ext4
3 1305MB 1024GB 1023GB
