I have dual boot installed in my machine. On windows the network interface works fine, however, in ubuntu, I cannot seem to get it to work. For starters, the wireless interface will only capture very dim signals. Unless my computer is standing directly next to the source, it is unusable. Even using ethernet, although the connection works, several times every minute I get a ERR_NETWORK_CHANGED error. This is not only restricted to chrome, it also happens when I am downloading files via ssh. I am thinking this has to do with the network drivers, but I know nothing about this. Here is some information about my computer:
***lsb_release -a***
No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.3 LTS Release: 20.04 Codename: focal
*uname -a* Linux Filipe-PC 5.4.0-91-generic #102-Ubuntu SMP Fri Nov 5 16:31:28 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
*rfkill list* 0: hci0: Bluetooth Soft blocked: yes Hard blocked: no 1: phy0: Wireless LAN Soft blocked: yes Hard blocked: no
*** ífconfig*** docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255 ether 02:42:f6:63:15:4c txqueuelen 0 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.0.104 netmask 255.255.255.0 broadcast 192.168.0.255 inet6 fe80::8250:952a:2c8d:4cb3 prefixlen 64 scopeid 0x20<link> ether b0:6e:bf:18:a1:43 txqueuelen 1000 (Ethernet) RX packets 386316 bytes 565360952 (565.3 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 141792 bytes 11451889 (11.4 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 127 base 0x5000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 loop txqueuelen 1000 (Local Loopback) RX packets 186 bytes 12031 (12.0 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 186 bytes 12031 (12.0 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
virbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 inet 192.168.122.1 netmask 255.255.255.0 broadcast 192.168.122.255 ether 52:54:00:9f:e8:51 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
*sudo lshw -C network* -network
description: Ethernet interface product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:02:00.0 logical name: enp2s0 version: 10 serial: b0:6e:bf:18:a1:43 size: 100Mbit/s capacity: 1Gbit/s width: 64 bits clock: 33MHz capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.048.00-NAPI duplex=full ip=192.168.0.104 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s resources: irq:127 ioport:d000(size=256) memory:ef404000-ef404fff memory:ef400000-ef403fff
-network DISABLED description: Wireless interface product: QCA9377 802.11ac Wireless Network Adapter vendor: Qualcomm Atheros physical id: 0 bus info: pci@0000:03:00.0 logical name: wlp3s0 version: 31 serial: 40:9f:38:41:7d:25 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless configuration: broadcast=yes driver=ath10k_pci driverversion=5.4.0-91-generic firmware=WLAN.TF.2.1-00021-QCARMSWP-1 latency=0 link=no multicast=yes wireless=IEEE 802.11 resources: irq:131 memory:ef200000-ef3fffff *-network DISABLED description: Ethernet interface physical id: 1 logical name: virbr0-nic serial: 52:54:00:9f:e8:51 size: 10Mbit/s capabilities: ethernet physical configuration: autonegotiation=off broadcast=yes driver=tun driverversion=1.6 duplex=full link=no multicast=yes port=twisted pair speed=10Mbit/s
If you need more information, please let me know. This situation has been present for 2 years and I decided to sit down and fix it.
Edit
Here is the output requested:
***sudo cat /var/lib/NetworkManager/NetworkManager.state***
[main] NetworkingEnabled=true WirelessEnabled=true WWANEnabled=true
Try disabling/decreasing the Wi-Fi power saver:
 sudo sed -i 's/wifi.powersave = 3/wifi.powersave = 2/' /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
If disabling the power-saver didn't work then try:
sudo rm -rf /lib/firmware/ath10k && sudo apt install --reinstall linux-firmware
Error404
  • 8,278
  • 35
  • 60
