First of all I'd like to say that I'm new to Ubuntu (former Windows user), so this might be a noob question. By the way, I was trying to play Rocket League using Heroic Games Launcher, but the performance is awful. I am sure that I am using my Intel Integrated Graphics instead of my Nvidia GPU. Here my overall specs:
Intel i5 8500 3 GHz GTX 1060 6gb 16gb RAM 2666 (2x8)
In Windows, I can use Rocket League Maximum Graphics with stable +85 fps, and in Ubuntu I never get more than 15 fps. When I open System Monitor, for some reason, I don't see the GPU. So, I googled how to see my PCI connections, and I see this
lspci -v
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
    DeviceName: Onboard - Other
    Subsystem: Gigabyte Technology Co., Ltd 8th Gen Core Processor Host Bridge/DRAM Registers
    Flags: bus master, fast devsel, latency 0
    Capabilities: <access denied>
    Kernel driver in use: skl_uncore
    Kernel modules: ie31200_edac
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 121 Bus: primary=00, secondary=01, subordinate=01, sec-latency=0 I/O behind bridge: 00004000-00004fff [size=4K] Memory behind bridge: a2000000-a30fffff [size=17M] Prefetchable memory behind bridge: 0000000090000000-00000000a1ffffff [size=288M] Capabilities: <access denied> Kernel driver in use: pcieport
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10) DeviceName: Onboard - Other Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH Thermal Controller Flags: fast devsel, IRQ 16 Memory at a341c000 (64-bit, non-prefetchable) [size=4K] Capabilities: <access denied> Kernel driver in use: intel_pch_thermal Kernel modules: intel_pch_thermal
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10) (prog-if 30 [XHCI]) DeviceName: Onboard - Other Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH USB 3.1 xHCI Host Controller Flags: bus master, medium devsel, latency 0, IRQ 126 Memory at a3400000 (64-bit, non-prefetchable) [size=64K] Capabilities: <access denied> Kernel driver in use: xhci_hcd Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10) DeviceName: Onboard - Other Subsystem: Intel Corporation Cannon Lake PCH Shared SRAM Flags: fast devsel Memory at a3416000 (64-bit, non-prefetchable) [disabled] [size=8K] Memory at a341b000 (64-bit, non-prefetchable) [disabled] [size=4K] Capabilities: <access denied>
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10) DeviceName: Onboard - Other Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH HECI Controller Flags: bus master, fast devsel, latency 0, IRQ 124 Memory at a341a000 (64-bit, non-prefetchable) [size=4K] Capabilities: <access denied> Kernel driver in use: mei_me
00:17.0 SATA controller: Intel Corporation Cannon Lake PCH SATA AHCI Controller (rev 10) (prog-if 01 [AHCI 1.0]) DeviceName: Onboard - SATA Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH SATA AHCI Controller Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 125 Memory at a3414000 (32-bit, non-prefetchable) [size=8K] Memory at a3419000 (32-bit, non-prefetchable) [size=256] I/O ports at 5030 [size=8] I/O ports at 5020 [size=4] I/O ports at 5000 [size=32] Memory at a3418000 (32-bit, non-prefetchable) [size=2K] Capabilities: <access denied> Kernel driver in use: ahci
00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #5 (rev f0) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 122 Bus: primary=00, secondary=02, subordinate=02, sec-latency=0 I/O behind bridge: [disabled] Memory behind bridge: a3300000-a33fffff [size=1M] Prefetchable memory behind bridge: [disabled] Capabilities: <access denied> Kernel driver in use: pcieport
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 123 Bus: primary=00, secondary=03, subordinate=03, sec-latency=0 I/O behind bridge: 00003000-00003fff [size=4K] Memory behind bridge: a3200000-a32fffff [size=1M] Prefetchable memory behind bridge: [disabled] Capabilities: <access denied> Kernel driver in use: pcieport
00:1f.0 ISA bridge: Intel Corporation Device a308 (rev 10) DeviceName: Onboard - Other Subsystem: Gigabyte Technology Co., Ltd Device 5001 Flags: bus master, medium devsel, latency 0
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10) DeviceName: Onboard - Sound Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH cAVS Flags: bus master, fast devsel, latency 32, IRQ 129 Memory at a3410000 (64-bit, non-prefetchable) [size=16K] Memory at a3100000 (64-bit, non-prefetchable) [size=1M] Capabilities: <access denied> Kernel driver in use: snd_hda_intel Kernel modules: snd_hda_intel, snd_sof_pci_intel_cnl
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10) DeviceName: Onboard - Other Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH SMBus Controller Flags: medium devsel, IRQ 16 Memory at a3418800 (64-bit, non-prefetchable) [size=256] I/O ports at efa0 [size=32] Kernel driver in use: i801_smbus Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10) DeviceName: Onboard - Other Subsystem: Intel Corporation Cannon Lake PCH SPI Controller Flags: fast devsel Memory at fe010000 (32-bit, non-prefetchable) [size=4K] Kernel driver in use: intel-spi Kernel modules: intel_spi_pci
01:00.0 VGA compatible controller: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] (rev a1) (prog-if 00 [VGA controller]) Subsystem: Micro-Star International Co., Ltd. [MSI] GP106 [GeForce GTX 1060 6GB] Flags: bus master, fast devsel, latency 0, IRQ 255 Memory at a2000000 (32-bit, non-prefetchable) [size=16M] Memory at 90000000 (64-bit, prefetchable) [size=256M] Memory at a0000000 (64-bit, prefetchable) [size=32M] I/O ports at 4000 [size=128] Expansion ROM at 000c0000 [disabled] [size=128K] Capabilities: <access denied> Kernel modules: nvidiafb, nouveau
01:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1) Subsystem: Micro-Star International Co., Ltd. [MSI] GP106 High Definition Audio Controller Flags: bus master, fast devsel, latency 0, IRQ 17 Memory at a3080000 (32-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: snd_hda_intel Kernel modules: snd_hda_intel
Isn't my PCI bridge supposed to be controlled by Nvidia? How do I change it?
