I installed a fresh version of Kubuntu 18.04.5 in my old MSI CR400 with Intel Celeron 900, 4 GB RAM and NVidia GeForce 8200M Graphics. First of all the normal boot from a USB Image doesn't go through, it get stuck in a black screen for eternity. I googled what caused this problem and folks here said I should probably run it with nomodeset which can be set at USB boot using f6. So I set it and it started working. Now when I finished installing and reboot, it reboots normally, but at a fixed resolution of 648x480. My screen is a 1366x768 display and the Windows 8.1 I am Dual Booting runs smooth on it. What's more is that during USB Live Boot with nomodeset enabled, it ran at a resolution of 1024x768. So next I disabled/removed nomodeset during the GRUB prompt by pressing e at boot time. But then it didn't even move to the login screen, it just stays blank.
Next I opened up a Stack Exchange thread and it said to change display drivers to NVidia Proprietary Drivers, which I did, only to find my system crashing as I opened System Settings to check / change my display resolution. This is not working at all. The thread later mentioned that the drivers from before version 40 don't support the display method or something.
Today, I decided to take one more shot and then ran into these same problems, so this time I followed this thread. But alas nothing worked. Do I have to make do with the bad resolution coz of the unsupported drivers or is there any other solution. Please help me, I need to make this work or else I am stuck using a really Intel N270 Powered Laptop.
Your card is somewhat older (it is good to keep the the old hardware alive) but you will have to install an older nvidia driver before you could get rid of the "nomodeset".
Add the "nomodeset" to grub again, install the Nvidia 340.xxx driver - then you should be go and remove that flag again. See installing Nvidia 340 driver which has been asked recently.
Don't forget to update-grubafter the changes you've made in /etc/default/grub
kanehekili
  • 7,426
