docker: Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/create": dial unix /var/run/docker.sock: connect: permission denied.
You have to add your user to the docker group by
sudo usermod -a -G docker $USER
then reboot and retry running Docker-related command.
N0rbert
  • 103,263
If you do not need to do anything more and in your environment has lots of users, just do the following and you would ready to use for all users,
[admin@localhost]$ systemctl enable --now docker
[admin@localhost]$ systemctl start docker
[admin@localhost]$ sudo chmod 777 /var/run/docker.sock
By using the above you can use the "docker" command for every user.
