So I actually figured out the issue while I was writing the question. As you can see from what I wrote in the beginning, it was a very long process (I had been working on it for about 2 days before I got to the point of wanting to ask for help).
If you look at the very end of the Q, I had received this message from dmesg during the boot process:
[FAILED] Failed to mount /boot
See 'systemctl status boot.mount' for details.
So, of course I tried systemctl status boot.mount to see what it said, but it said boot.mount is active (green), it's loaded and functioning properly, even though /boot was empty unless I manually mounted /dev/sda2 (which is exactly the opposite of what I would expect).
So I started thinking something might be wrong with the service. I disabled boot.mount even though it said it was working properly:
systemctl disable --now boot.mount
I tried to re-enable it, but got an error:
systemctl enable --now boot.mount
Failed to enable unit: Unit /run/systemd/generator/boot.mount is transient or generated
OK, that makes sense, it's triggered through the boot process and cannot be invoked through a user command. So I tried to re-mount all devices with:
mount -a
And saw that there was an error in the /etc/fstab file:
error: rw,relatime is not a valid file system
(or something to that effect).
The key here is, if I hadn't tried mounting the filesystem manually, I would have never received that feedback. The error message from mount -a one gets when fstab contains improper syntax is incredibly helpful. A lot more helpful than:
... and then seeing a "working" systemd unit for boot.mount when /boot is not mounting (even though it did get me to the right place eventually).
So I edited the fstab and entered the filesystem info for the /boot partition that failed to mount, then I re-ran mount -a (which essentially does the same thing as boot.mount) and got a positive response.
Now the two partitions are mounting properly after a reboot, and all is good in the land of horseradish and marmalade.
If this does not address any of your issues, here are some additional notes of the process I went through before getting to the point above where I was looking for help (feel free to stop reading after you get to your problem):
The original issue I was having two days ago was the system trying to boot from kernels no longer on the system. So, after booting with the live CD, I deleted the /boot folder's contents (where all the initrd files are located).
I figured I would just re-create the initramfs using update-initramfs -c -k all from the current kernels I had installed, but then I learned that I could not re-create the config or System.map files with depmod alone. This turned out to be a little more troublesome than I had bargained for.
I found the easiest way to re-generate or acquire all these files is to:
- delete all contents of
/boot,
- uninstall any
linux-image, linux-header and linux-modules files I had no intention of using,
- delete all residual directories in
/usr/lib/modules, and then
- re-install
linux-image, linux-modules and linux-headers files I intended on using (the most current generic two versions)
Note: Re-installing these 3 types of files all at the same time was how I managed to get the /boot/System.map and /boot/config files back - before only re-installing the linux-image files did not do it. It's possible they're included with modules (modules would make sense), or headers packages, but this is what worked for me.
- Then I ran
update-grub after re-installing those files and confirming /boot was populated correctly.
- I also ran
bootctl install and /etc/kernel/postinst.d/zz-udpate-systemd-boot, so I would have systemd-boot installed as a fallback.
At one point after a reboot, I had to re-configure system.target to multi-user.target instead of graphical.target, probably due to having chrooted with all those mounts in a graphical live CD to run the boot-repair program a couple days ago, which requires graphics (and I believe /dev/pts /tmp and /run were required to get display :0.0 to work):
systemctl set-default multi-user.target
Ok that's about it. Hope this helps someone.
