There seems to be an issue with libpulse-dev in Ubuntu 21.10 because if I want to install libsdl2-dev on a fully up-to-date system, I get:
libpulse-dev : Depends: libpulse0 (= 1:15.0+dfsg1-1ubuntu2) but 1:15.0+dfsg1-1ubuntu2.1 is to be installed
# dpkg --get-selections | grep hold
root@gamer2:/# apt update
Hit:1 https://repo.steampowered.com/steam stable InRelease
Hit:2 http://ca.archive.ubuntu.com/ubuntu impish InRelease
Hit:3 http://ca.archive.ubuntu.com/ubuntu impish-updates InRelease
Hit:4 http://security.ubuntu.com/ubuntu impish-security InRelease
Hit:5 http://ca.archive.ubuntu.com/ubuntu impish-backports InRelease
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
root@gamer2:/# apt dist-upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@gamer2:/# apt install libsdl2-dev
The following information may help resolve the situation:
The following packages have unmet dependencies: libpulse-dev : Depends: libpulse0 (= 1:15.0+dfsg1-1ubuntu2) but 1:15.0+dfsg1-1ubuntu2.1 is to be installed Depends: libpulse-mainloop-glib0 (= 1:15.0+dfsg1-1ubuntu2) but 1:15.0+dfsg1-1ubuntu2.1 is to be installed E: Unable to correct problems, you have held broken packages. root@gamer2:/# dpkg --get-selections | grep hold root@gamer2:/#
How do I solve this?
This is on a fresh 64b ubuntu21.10 install.
UPDATE
# apt-cache policy libpulse-dev
libpulse-dev:
  Installed: (none)
  Candidate: 1:15.0+dfsg1-1ubuntu2
  Version table:
     1:15.0+dfsg1-1ubuntu2.2 1 (phased 20%)
        500 http://ca.archive.ubuntu.com/ubuntu impish-updates/main amd64 Packages
     1:15.0+dfsg1-1ubuntu2 500
        500 http://ca.archive.ubuntu.com/ubuntu impish/main amd64 Packages
Ubuntu version, kernel, and architecture:
root@gamer2:/# cat /etc/issue
Ubuntu 21.10 \n \l
root@gamer2:/# uname -a Linux gamer2 5.13.0-22-generic #22-Ubuntu SMP Fri Nov 5 13:21:36 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
UPDATE 2
It seems to get libpulse0 from impish, but libpulse-dev from impish-updates, but why?
root@gamer2:/# apt-cache policy libpulse0
libpulse0:
  Installed: 1:15.0+dfsg1-1ubuntu2.1
  Candidate: 1:15.0+dfsg1-1ubuntu2.1
  Version table:
 *** 1:15.0+dfsg1-1ubuntu2.1 100
        100 /var/lib/dpkg/status
root@gamer2:/# apt install libpulse0
libpulse0 is already the newest version (1:15.0+dfsg1-1ubuntu2.1).
libpulse0 set to manually installed.
UPDATE 3
This PC has no non-default repositories, nor ever had any non-default repositories configured.
There are no holds:
$ apt-mark showhold
Bram
  • 3,699
"(phased 20%)"
see https://wiki.ubuntu.com/PhasedUpdates https://wiki.ubuntu.com/ErrorTracker/PhasedUpdates
You can wait until the phasing period is over (currently on 50%) or install the package providing the version numbers:
Either
sudo apt install libpulse-dev=1:15.0+dfsg1-1ubuntu2 libpulse0=1:15.0+dfsg1-1ubuntu2 libpulse-mainloop-glib0=1:15.0+dfsg1-1ubuntu2
or
sudo apt install libpulse-dev=1:15.0+dfsg1-1ubuntu2.2 libpulse0=1:15.0+dfsg1-1ubuntu2.2 libpulse-mainloop-glib0=1:15.0+dfsg1-1ubuntu2.2
This seems to be a specific case that may deserve a bug report on Launchpad see also https://answers.launchpad.net/ubuntu/+source/pulseaudio/+question/699828
m_hampl
  • 66
