Before the first coffee of the day sleepy me had the great idea to uninstall nautilus.
sudo apt remove nautilus
Now I am unable to reinstall it.
philipp@X1C:~$ sudo apt install nautilus
Reading package lists... Done
Building dependency tree... Done
nautilus : Depends: libnautilus-extension1a (= 1:40.2-1ubuntu1) but 1:40.2-1ubuntu1ppa1 is to be installed
Depends: nautilus-data (= 1:40.2-1ubuntu1) but 1:40.2-1ubuntu1ppa1 is to be installed
N: Ignoring file 'fman.list#' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
How do I resolve the unmet dependencies and install nautilus again?
Edit:
libnautilus-extension1a and nautilus-data seem to be installed.
Thanks!
