Incrementing a variable var works in bash when enclosed in double parentheses like (( var++ )). But I have found that it fails if variable is set to 0 beforehand like var=0.
$ a=0
$ ((a++)) && echo "command succeeded" || echo "command failed"
command failed
$ a=1 $ ((a++)) && echo "command succeeded" || echo "command failed" command succeeded
Can someone explain this behavior?
Environment:
I am using gnome-terminal on Ubuntu Desktop 18.04.5 LTS.
muru
  • 207,228
Saad
  • 111
With credit from here: https://unix.stackexchange.com/questions/146773/why-bash-increment-n-0n-return-error
The return value of (( expression )) does not indicate an error status, but, from the bash manpage:
((expression)) The expression is evaluated according to the rules described below under ARITHMETIC EVALUATION. If the value of the expression is non-zero, the return status is 0; otherwise the return status is 1. This is exactly equivalent to let "expression".
In ((a++))you are doing a post increment. The value of a is 0 so 1 is returned, after that, it is incremented.
Compare
$ unset a
$ ((a++)) ; echo Exitcode: $? a: $a
Exitcode: 1 a: 1
versus
$ unset a
$ ((++a)) ; echo Exitcode: $? a: $a
Exitcode: 0 a: 1
A pre-increment, so a has become 1 and 0 is returned.
vanadium
  • 97,564
This works for me (in bash in Ubuntu),
$ a=0
$ echo $((a++))
$ echo $((a++))
$ echo $((a++))
$ echo $((a++))
$ echo $a
Notice the difference with
$ a=0
$ echo $((++a))
$ echo $((++a))
$ echo $((++a))
$ echo $a
sudodus
  • 47,684
