Tried to install steam-installer with Ubuntu Software, got this very helpful error:
Then I tried the command line:
$ sudo apt install steam-installer
steam-installer : Depends: steam (= 1:1.0.0.61-2ubuntu3)
So steam-installer depends on steam, which cannot be resolved! What? Is the Ubuntu Steam package just broken?
Update:
$ sudo apt update
Hit:1 http://mx.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://mx.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:4 http://mx.archive.ubuntu.com/ubuntu focal-backports InRelease
Reading package lists... Done
Building dependency tree
6 packages can be upgraded. Run 'apt list --upgradable' to see them.
$ sudo apt upgrade
Calculating upgrade... Done
The following packages will be upgraded:
libssl1.1 openssl python3-software-properties software-properties-common software-properties-gtk
ubuntu-advantage-tools
6 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 2 902 kB of archives.
After this operation, 13.3 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://mx.archive.ubuntu.com/ubuntu focal-updates/main amd64 libssl1.1 amd64 1.1.1f-1ubuntu2.10 [1 322 kB]
Get:2 http://mx.archive.ubuntu.com/ubuntu focal-updates/main amd64 openssl amd64 1.1.1f-1ubuntu2.10 [620 kB]
Get:3 http://mx.archive.ubuntu.com/ubuntu focal-updates/main amd64 ubuntu-advantage-tools amd64 27.4.2~20.04.1 [859 kB]
Get:4 http://mx.archive.ubuntu.com/ubuntu focal-updates/main amd64 software-properties-common all 0.99.9.8 [10.6 kB]
Get:5 http://mx.archive.ubuntu.com/ubuntu focal-updates/main amd64 software-properties-gtk all 0.99.9.8 [66.0 kB]
Get:6 http://mx.archive.ubuntu.com/ubuntu focal-updates/main amd64 python3-software-properties all 0.99.9.8 [24.9 kB]
Fetched 2 902 kB in 4s (661 kB/s)
Preconfiguring packages ...
(Reading database ... 418427 files and directories currently installed.)
Preparing to unpack .../0-libssl1.1_1.1.1f-1ubuntu2.10_amd64.deb ...
Unpacking libssl1.1:amd64 (1.1.1f-1ubuntu2.10) over (1.1.1f-1ubuntu2.9) ...
Preparing to unpack .../1-openssl_1.1.1f-1ubuntu2.10_amd64.deb ...
Unpacking openssl (1.1.1f-1ubuntu2.10) over (1.1.1f-1ubuntu2.9) ...
Preparing to unpack .../2-ubuntu-advantage-tools_27.4.2~20.04.1_amd64.deb ...
Unpacking ubuntu-advantage-tools (27.4.2~20.04.1) over (27.4.1~20.04.1) ...
Preparing to unpack .../3-software-properties-common_0.99.9.8_all.deb ...
Unpacking software-properties-common (0.99.9.8) over (0.98.9.5) ...
Preparing to unpack .../4-software-properties-gtk_0.99.9.8_all.deb ...
Unpacking software-properties-gtk (0.99.9.8) over (0.98.9.5) ...
Preparing to unpack .../5-python3-software-properties_0.99.9.8_all.deb ...
Unpacking python3-software-properties (0.99.9.8) over (0.98.9.5) ...
Setting up libssl1.1:amd64 (1.1.1f-1ubuntu2.10) ...
Setting up python3-software-properties (0.99.9.8) ...
Setting up ubuntu-advantage-tools (27.4.2~20.04.1) ...
Setting up openssl (1.1.1f-1ubuntu2.10) ...
Setting up software-properties-common (0.99.9.8) ...
Setting up software-properties-gtk (0.99.9.8) ...
Processing triggers for dbus (1.12.16-2ubuntu2.1) ...
Processing triggers for shared-mime-info (1.15-1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for libglib2.0-0:amd64 (2.64.6-1~ubuntu20.04.4) ...
Processing triggers for libc-bin (2.31-0ubuntu9.3) ...
Processing triggers for man-db (2.9.1-1) ...
Update2:
steam:i386 : Depends: libgl1-mesa-dri:i386 (>= 17.3) but it is not going to be installed or
libtxc-dxtn0:i386 but it is not installable
Depends: libgl1-mesa-glx:i386 but it is not going to be installed
Depends: libgpg-error0:i386 (>= 1.10) but it is not going to be installed
Depends: libudev1:i386 but it is not going to be installed
Depends: libxcb-dri3-0:i386 (>= 1.11.1) but it is not going to be installed
Depends: libxinerama1:i386 (>= 2:1.1.1) but it is not going to be installed
Depends: libc6:i386 (>= 2.15) but it is not going to be installed
Depends: libstdc++6:i386 (>= 4.8) but it is not going to be installed
Depends: libx11-6:i386 but it is not going to be installed
Recommends: libxss1:i386 but it is not going to be installed
Recommends: mesa-vulkan-drivers:i386 but it is not going to be installed
sources.list:
#deb cdrom:[Ubuntu 20.04 LTS _Focal Fossa_ - Release amd64 (20200423)]/ focal main restricted
See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
newer versions of the distribution.
deb http://mx.archive.ubuntu.com/ubuntu/ focal main restricted
deb-src http://mx.archive.ubuntu.com/ubuntu/ focal main restricted
Major bug fix updates produced after the final release of the
distribution.
deb http://mx.archive.ubuntu.com/ubuntu/ focal-updates main restricted
deb-src http://mx.archive.ubuntu.com/ubuntu/ focal-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb http://mx.archive.ubuntu.com/ubuntu/ focal universe
deb-src http://mx.archive.ubuntu.com/ubuntu/ focal universe
deb http://mx.archive.ubuntu.com/ubuntu/ focal-updates universe
deb-src http://mx.archive.ubuntu.com/ubuntu/ focal-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb http://mx.archive.ubuntu.com/ubuntu/ focal multiverse
deb-src http://mx.archive.ubuntu.com/ubuntu/ focal multiverse
deb http://mx.archive.ubuntu.com/ubuntu/ focal-updates multiverse
deb-src http://mx.archive.ubuntu.com/ubuntu/ focal-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb http://mx.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
deb-src http://mx.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
Uncomment the following two lines to add software from Canonical's
'partner' repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu focal partner
deb-src http://archive.canonical.com/ubuntu focal partner
deb http://security.ubuntu.com/ubuntu focal-security main restricted
deb-src http://security.ubuntu.com/ubuntu focal-security main restricted
deb http://security.ubuntu.com/ubuntu focal-security universe
deb-src http://security.ubuntu.com/ubuntu focal-security universe
deb http://security.ubuntu.com/ubuntu focal-security multiverse
deb-src http://security.ubuntu.com/ubuntu focal-security multiverse
This system was installed using small removable media
(e.g. netinst, live or single CD). The matching "deb cdrom"
entries were disabled at the end of the installation process.
For information about how to configure apt package sources,
see the sources.list(5) manual.
I think I've never fiddled with that.
