I have an Nvidia RTX 3070 and a Samsung C49RG90 monitor. The monitor is connected to the video card via HDMI. Everything works fine, unless I suspend the system and then wake it back up. When that happens, the resolution changes to 1024x768. I can log in and open the Nvidia control panel and set it back to the correct resolution just fine, but if I put it to sleep again, the resolution always returns to 1024x768.
I am using version 470.86 of the Nvidia driver, but older versions behave the same way.
When I manually set the resolution after wake and then run xrandr, I get this:
Screen 0: minimum 8 x 8, current 5120 x 1440, maximum 32767 x 32767
HDMI-0 connected primary 5120x1440+0+0 (normal left inverted right x axis y axis) 1mm x 1mm
3840x1080 59.97 +
5120x1440 59.98* 29.98
3840x2160 59.94 50.00 29.97 25.00 23.98
2560x1440 59.95
2560x1080 60.00 59.94
1920x1080 60.00 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
When I put the machine to sleep and then wake it again, and then run xrandr, I get this:
HDMI-0 connected primary 1024x768+3327+362 (normal left inverted right x axis y axis) 0mm x 0mm panning 5120x1440+0+0
3840x1080 59.97 +
5120x1440 59.98 29.98
2560x1440 59.95
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
1024x768 (0x208) 94.500MHz +HSync +VSync
h: width 1024 start 1072 end 1168 total 1376 skew 0 clock 68.68KHz
v: height 768 start 769 end 772 total 808 clock 85.00Hz
Here's my xorg.conf file:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 470.57.01
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Samsung C49RG9x"
HorizSync 30.0 - 160.0
VertRefresh 24.0 - 120.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce RTX 3070"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "5120x1440 +0+0; 800x600 +0+0; 640x480 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
I understand that more information will likely be required, but I'm not sure where to look.
