I am using a Thinkpad T510 and I often boot it in a ThinkPad Mini Dock Plus Series 3 (EU). The problem is that if I boot it with the lid closed, I can see grub, I can see the Ubuntu boot splash, but after that my external monitor (connected via VGA) turns off, and I have to open the lid and tell the NVIDIA driver manually to use the external screen and turn off the built in LCD panel. Is there a way to put it into an udev rule, or something like that to avoid the manual switching?
Asked
Active
Viewed 5,180 times
There are some tools to automate it like RandR, disper, displex or this one http://gnomefiles.org/content/show.php/Laptop+external+display+hotplugging?content=138742
Cmorales
- 1,318
I adjusted myself a script I found to my needs.
You can ignore the wacom commands. Those are just to match the input layer of the tablet to the screen orientation.
#!/bin/bash
#!/bin/sh
# wait for the dock state to change
sleep 2.0
DOCKED=$(cat /sys/devices/platform/dock.0/docked)
case "$DOCKED" in
"0")
#undocked event - lets remove all connected outputs apart from LVDS
for output in $(/usr/bin/xrandr -d :0.0 --verbose|grep " connected"|grep -v LVDS|awk '{print $1}')
do
/usr/bin/xrandr -d :0.0 --output $output --off
done
xrandr --output LVDS1 --rotation normal
xsetwacom set "Wacom ISDv4 90 Pen stylus" MapToOutput LVDS1
xsetwacom set "Wacom ISDv4 90 Pen eraser" MapToOutput LVDS1
# rotates the tablet input to the according position (half=180°, (c)cw=(counter)clockwise, none=normal)
xsetwacom set "Wacom ISDv4 90 Pen stylus" rotate none
# if multiouch present set: xsetwacom set "Wacom ISDv4 E6 Finger touch" rotate half
xsetwacom set "Wacom ISDv4 90 Pen eraser" rotate none
"1")
## rotates internal Laptop Display LVDS1 to inverted
xrandr --output HDMI2 --auto --above LVDS1
xrandr --output LVDS1 --rotation inverted
xsetwacom set "Wacom ISDv4 90 Pen stylus" rotate half
xsetwacom set "Wacom ISDv4 90 Pen eraser" rotate half
esac
exit 0
It identifies a status file in /sys/devices/platform/dock.0 wheter it has the value 1 for docked or 0 for undocked an triggers xrandr to adjust the display output to an extended dektop using the inbuilt display LVDS1 an configuring the external display HDMI2 above.
0x2b3bfa0
- 9,110
- 7
- 38
- 55
phaeton616
- 116
