I am attempting to install howdy, and apt yields this result:
howdy : Depends: libopencv-dev but it is not going to be installed
If I try to install directly libopencv-dev it says the same thigs with other packages.
libopencv-dev : Depends: libopencv-contrib-dev (= 4.2.0+dfsg-5+20.04.sav2) but it is not going to be installed
Depends: libopencv-dnn-dev (= 4.2.0+dfsg-5+20.04.sav2) but it is not going to be installed
Depends: libopencv-superres-dev (= 4.2.0+dfsg-5+20.04.sav2) but it is not going to be installed
Depends: libopencv4.2-java (= 4.2.0+dfsg-5+20.04.sav2) but it is not going to be installed
Depends: libopencv-contrib4.2 (>= 4.2.0+dfsg) but it is not going to be installed
Now I haven't done any work with computer vision before, and I've tried pretty much google offered, among which running the command
sudo apt list --installed | grep opencv
Which told me I had installed the following packages
libopencv-core4.2/focal,now 4.2.0+dfsg-5+20.04.sav2 amd64 [installed,automatic]
libopencv-imgcodecs4.2/focal,now 4.2.0+dfsg-5+20.04.sav2 amd64 [installed,automatic]
libopencv-imgproc4.2/focal,now 4.2.0+dfsg-5+20.04.sav2 amd64 [installed,automatic]
libopencv-videoio4.2/focal,now 4.2.0+dfsg-5+20.04.sav2 amd64 [installed,automatic]
As per the guide I found I removed them, ran autoremove, and then retried with howdy. Same result. How do I solve this? It would be amazing to skip some of the password-typing that linux requires.
Edit: as by request, the result of "apt-cache policy libopencv-dev howdy"
libopencv-dev:
Installed: (none)
Candidate: 4.2.0+dfsg-5+20.04.sav2
Version table:
4.2.0+dfsg-5+20.04.sav2 500
500 http://ppa.launchpad.net/savoury1/blender/ubuntu focal/main amd64 Packages
4.2.0+dfsg-5 500
500 http://it.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
howdy:
Installed: (none)
Candidate: 2.6.1
Version table:
2.6.1 500
500 http://ppa.launchpad.net/boltgolt/howdy/ubuntu focal/main amd64 Packages
500 http://ppa.launchpad.net/boltgolt/howdy/ubuntu focal/main i386 Packages
The result of apt-cache policy is here
