A fresh install of ubuntu 20.04.3 in a Razor Blade Pro 17 laptop, the wifi card never showed up.
uname -a outputs
Linux Razor 5.11.0-41-generic #45~20.04.1-Ubuntu SMP Wed Nov 10 10:20:10 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
dmesg | grep iwlwifi outputs:
[ 2.333506] iwlwifi 0000:3e:00.0: api flags index 2 larger than supported by driver <br>
[ 2.333519] iwlwifi 0000:3e:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22 <br>
[ 2.333790] iwlwifi 0000:3e:00.0: loaded firmware version 59.601f3a66.0 cc-a0-59.ucode op_mode iwlmvm <br>
[ 2.607066] iwlwifi 0000:3e:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
I also tried this Intel article without success...
After that, I tried Intel support, but they sent me here because it's not a firmware problem but a driver problem, and drivers are provided by Ubuntu...
There it is
[ 2.498488] iwlwifi 0000:3e:00.0: api flags index 2 larger than supported by driver<br>
[ 2.498504] iwlwifi 0000:3e:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22<br>
[ 2.498780] iwlwifi 0000:3e:00.0: loaded firmware version 59.601f3a66.0 cc-a0-59.ucode op_mode iwlmvm<br>
[ 2.678275] iwlwifi 0000:3e:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
Same results!
It seems that I've already the last driver or it doesn't want to replace the old ones?!?
I updated to the latest kernel
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.187.23_all.deb
The problem persists.
As of 2022-01-18, the problem still on event if I update to the last kernel wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.187.23_all.deb
Any clue now?
