I have installed Wireguard with following commands:
sudo apt update
sudo apt install wireguard
Then I have installed resolvconf:
sudo apt install resolvconf
Created keys:
umask 077
wg genkey | sudo tee /etc/wireguard/private.key
sudo cat /etc/wireguard/private.key | wg pubkey | sudo tee /etc/wireguard/public.key
Finally, created config:
sudo nano /etc/wireguard/wg0.conf
# below is the content of the config file
[Interface]
PrivateKey = omitted
Address = 10.9.0.7/32
DNS = 1.0.0.1
[Peer]
PublicKey = omitted
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = 95.87.101.10:51820
After executing sudo wg-quick up wg0 all my applications are left without internet.
Internet comes back after I sudo wg-quick down wg0 Wireguard.
I do not have access to the server, it is maintained by the company.
I can only tamper with my own machine.
I am not skilled with networking, my company said to just follow above instructions and everything will work, but here is what I have tried to solve the problem:
I have tried suggestions from this question but no success.
sudo wg gave the following output:
interface: wg0
public key: y5ZpnepnWHWBOvm04iDUh/+XgLIZKSOClI4It5D/ESU=
private key: (hidden)
listening port: 43460
fwmark: 0xca6c
peer: KIkiNWfiSEGYbXAGvNau8kOlG8rqFfEFeNzPjnUzz0Q=
endpoint: 95.87.101.10:51820
allowed ips: 0.0.0.0/0, ::/0
transfer: 0 B received, 296 B sent
I have assumed that handshake works, but something else obstructs internet connection.
ip route show gave me this:
default via 192.168.1.1 dev wlx3c7c3f49907c proto dhcp metric 600
169.254.0.0/16 dev wlx3c7c3f49907c scope link metric 1000
192.168.1.0/24 dev wlx3c7c3f49907c proto kernel scope link src 192.168.1.7 metric 600
After googling, I came to the conclusion that DHCP screws default route, but I do not know how to fix it. I have tried sudo ip route add default via 192.168.1.1 but that did not help either. ip route while Wireguard is on gives following output:
192.168.1.0/24 dev wlx3c7c3f49907c proto kernel scope link src 192.168.1.6 metric 600
I have tried sudo cat /proc/sys/net/ipv4/ip_forward but that did not help either.
This is the best I can do, since I do not know much about networking. I came across this site after googling so I have decided to ask for help, in a desperate hope that a solution will be found.
If you need further info leave a comment and I will reply.
